TRadarSeries with custom axes
mrepec
Post by mrepec » Wed Nov 21, 2012 8:47 am
hello
is there any known solution to do this, maybe in beta ? or in future plans (close future:) )?
i can't normalize values to show it on same axis, and doesn't matter how custom axes will be painted (with x shift or diffrent angle) - they just need to kept scale. I will be very grateful for any suggestion how to do it, and if there is no other way, where to look in teechart sources for easiest implement this in custom series class
regards
mr
Re: TRadarSeries with custom axes
Post by Narcís » Wed Nov 21, 2012 11:24 am
Hi mr,
I'm afraid not but we could add it to the wish-list to be considered for inclusion in future releases.
Could you please give us more detailed information about what you are trying to achieve so that we can try to help you? Some images would help.
mrepec
Post by mrepec » Fri Nov 23, 2012 6:03 am
sorry for delay in the answer, please see the attached document with examples, it should clarify all... :)
Spider.zip
(369.6 KiB) Downloaded 364 times
Post by Narcís » Fri Nov 23, 2012 7:58 am
Hi mr,
Thanks for the info. Looks like somewhat complicated as all series use all axes and each value in the series plots against a different axis. Currently, one series only supports one custom axis. Anyway, I have added your request (TV52016430) to the wish-list to be considered for inclusion in future releases.
