GetTeeBrush and TGanttSeries
Friis
Post by Friis » Thu Nov 15, 2012 10:55 am
Two questions:
1) I would like to put a brush on a TGanttSeries - the code below doesn't allow me to do that? How do I assing the Brush to the TGanttseries??
2) Is it possible to assing different types of Brush to different Points in the same GanttSeries? How do I do that?
procedure TForm10.FormCreate(Sender: TObject);
ABitmap : TBitmap;
s : shortstring;
ABitmap := TBitmap.Create;
GetTeeBrush(3,ABitmap);
with Chart1.AddSeries(TGanttSeries.Create(self)) as TGanttSeries do
    ParentChart := Chart1;
    ColorEachPoint := true;
    pointer.Brush.Image.Assign(ABitmap);
    Title := 'PO Planned';
    ShowInLegend := true;
    XValues.Order:=loNone;
    Marks.visible := true;
    Marks.Transparent := true;
    Xvalues.DateTime := true;
    with Chart1[Chart1.SeriesCount-1] as TGanttSeries do
        Pointer.VertSize:=10;
        s := 'hej';
        AddGantt(now,now+1,-1,s);
Re: GetTeeBrush and TGanttSeries
Post by Yeray » Fri Nov 16, 2012 3:33 pm
Hello Hans,
It seems that the patterns based on images work fine with the TLineSeries, but the don't with the TPointSeries nor with the TGanttSeries. I've added it to the defect list to be revised for next releases (TV52016419).
However, the regular patterns seem to work fine. And you could change the pattern depending on the ValueIndex, at the OnGetPointerStyle event:
  private
    { Private declarations }
    Function SeriesGetPointerStyle(Sender:TChartSeries; ValueIndex:Integer):TSeriesPointerStyle;
  with Chart1.AddSeries(TGanttSeries) as TGanttSeries do
    FillSampleValues(10);
    OnGetPointerStyle:=SeriesGetPointerStyle;
Function TForm1.SeriesGetPointerStyle(Sender:TChartSeries; ValueIndex:Integer):TSeriesPointerStyle;
  Chart1.Canvas.Brush.Style:=TBrushStyle(2+(ValueIndex mod 6));
  result:=psRectangle;
