Accesss Violation TChart an TGridBandTool
WilliEbert
Post by WilliEbert » Tue Nov 13, 2012 5:47 pm
if i add to a TChart a TGridBandTool in design mode there is always a access violation.
I use Delphi XE2 on Windows 7 32bit with TeeChart Pro 2012.5
Attached is the error stack from Delphi
Your sincerely
Willi
Sanctuary.ProductTimer.txt.zip
(1.33 KiB) Downloaded 557 times
Re: Accesss Violation TChart an TGridBandTool
Post by Yeray » Wed Nov 14, 2012 9:35 am
There was a similar error detected in that release as you can read here:
http://www.teechart.net/support/viewtop ... =3&t=13458
As you can also see in the thread above, it has been fixed in the latest release. I'm not sure if it's exactly what you are getting, but I'd suggest you to give it a try to the latest version to see if it works fine for you.
WilliEbert
Post by WilliEbert » Wed Nov 14, 2012 8:30 pm
Hello Yeray,
you are right. With the actual version from November 06 the error is gone.
Thank you very much.
Your sincerely
Willi
