phocasdev
- Newbie
Post
by phocasdev » Thu Sep 27, 2012 6:41 am
My application charts a dataset and allows the user to choose the chart type from a list; bar, area, line and pie. They can double-click any of the series to see the data in another form. The bar, area and line charts work just fine. The pie one doesn't and it seems that the 'OnClickSeries' event doesn't fire. This 100% definitely used to work in an older version of TChart, but the current (v2112.06.120613) version does not.
I have tried setting the Series.OnClick instead (as per below code) of the Chart.OnClickSeries and it makes no difference - the procedure is never fired.
Any suggestions/solutions gratefully received.
Code snippet;
// When creating the chart
for fnl := 0 to MyChart.SeriesCount-1 do
MyChart.Series[fnl].OnClick := ChartSeriesClick;
// Series OnClick.
procedure MyForm.ChartSeriesClick(Sender: TChartSeries; ValueIndex: Integer; Button: TMouseButton; Shift: TShiftState; X, Y: Integer);
if Sender is TPieSeries then
ClickValueVariable := Sender.ValueMarkText[ValueIndex]
ClickValueVariable := Sender.Title;
Post
by Yeray » Thu Sep 27, 2012 3:07 pm
I'm trying to reproduce this with the code below but both the Series' OnClick event and the Clicked function in the OnMouseMove event seem to work fine for me here:
uses Series;
Chart1.View3D:=false;
with Chart1.AddSeries(TPieSeries) as TPieSeries do
FillSampleValues;
OnClick:=SeriesOnClick;
Y: Integer);
//test 1
//Caption:=IntToStr(Chart1[0].Clicked(X,Y));
procedure TForm1.SeriesOnClick(Sender: TChartSeries; ValueIndex: Integer; Button:TMouseButton;
//test 2
Caption:=IntToStr(ValueIndex);
phocasdev
- Newbie
Post
by phocasdev » Fri Sep 28, 2012 2:11 am
After cloning my code into a fresh project, I stumbled on the cause of the problem.
For TBarSeries, TAreaSeries and TLineSeries, the event OnClickBackground only fires when you click the background.
For TPieSeries, the OnClickBackground event fires all the time - overriding the OnClickSeries and the Series.OnClick.
Post
by Yeray » Fri Sep 28, 2012 8:43 am
I think I found what really makes the difference, at least for me here: the TeeCommander.
The code I posted
above behaves differently when you have or you haven't a TeeCommander on the form. Is it possible that you are using a TeeCommander too?
Having a TeeCommander on the form, when you click on the TPieSeries you can drag the clicked slice to explode it. When you've entered in this "mode", these two events (OnClickSeries and the Series.OnClick) aren't checked.
You can disable this "mode" with:
TeeCommander1.EnablePieExploding:=false;
Could you please confirm this is what is causing the problem for you?
