Bar Charts & X Axis
JobyLeigh
Bar Charts & X Axis
Post by JobyLeigh » Thu Sep 06, 2012 3:27 pm
Hi there everyone,
Probably doing something really stupid (hopefully...) but I have a database table which I am trying to display in a Bar Chart. Data similar to as follows:
PUPILID PUPILNAME VALUE
1 Ben 15
2 Rob 17
3 Geoff 12
4 Wendy 16
5 Jenny 15
The idea is that VALUE would appear on the Y Axis, and each Bar within the Chart would represent a Pupil. With this in mind, I want the X Axis to say, underneath each Bar, the corresponding Pupil Name. However, whenever I set the XValue.ValueSource to PUPILNAME, it would error with (for example) "'BEN' is not a valid floating point value".
What do I have to turn off or change so the X Axis does not expect a floating point value? Or in order to display this field do I need to do something else entirely?
Ben
Re: Bar Charts & X Axis
Post by Yeray » Fri Sep 07, 2012 8:43 am
Hi Ben,
You could set the PUPILNAME to be used as the series Labels, LabelsSource, instead of XValues.ValueSource.
There is an example of how to do something like this in the "Tutorial 8 - ADO Database access".
JobyLeigh
Post by JobyLeigh » Fri Sep 07, 2012 9:43 am
Perfect!
Thanks for your quick response.
Kind regards,
Ben
