Multiple 3D Series plotted incorrectly
JonM
Post by JonM » Wed Aug 15, 2012 1:05 pm
Hello
I am trying to make a 3D plot of several series. I basically have one TTriSurfaceSeries and several TPoint3DSeries (plotted as points). I have made the TTriSurfaceSeries semi transparent and would like to show the TPoint3DSeries above and below the TTriSurfaceSeries surface depending on the data point’s position in 3D space. What I see is that each series work independently to each other and whether they appear above or below the surface depends on the drawing order of the series not the 3D position of the data..
This is not a proper 3D rendition of the data. I am using Delphi 2007 (.Net) with Tchart 7.12.
Does your latest version of Tchart .Net fix this fundamental problem?
Thanks Frank
Re: Multiple 3D Series plotted incorrectly
Post by Sandra » Thu Aug 16, 2012 11:33 am
Hello Frank,
We don't consider this problem as a bug. Basically, is a behavior of canvas where we draw TeeChart in VCL and .NET. If you want sereis draw as you want, you need use canvas OpenGL in VCL and in .Net. You can use OpenGL as explain here:
In VCL:
You only need add OpenGL component as do in next project
TriSurfaceTestOpenGL.zip
(4.35 KiB) Downloaded 980 times
In .Net.
You need add the TeeChart.OpenGl.dll assembly and add the component in the chart as do in next code:
        Steema.TeeChart.Styles.Points3D Series2;
        Steema.TeeChart.Styles.TriSurface Series1;
            Series2 = new Steema.TeeChart.Styles.Points3D(tChart1.Chart);
            Series1 = new Steema.TeeChart.Styles.TriSurface(tChart1.Chart);
            Steema.TeeChart.Tools.Rotate rotate = new Steema.TeeChart.Tools.Rotate(tChart1.Chart);
            teeOpenGL1.Chart = tChart1;
            tChart1.Aspect.Chart3DPercent = 100;
            //   teeOpenGL1.Canvas.Brush.Transparency = 50;
            //Add values in Series1:
            Series1.Add(0.872, 2.842, 0.592);
            Series1.Add(0.733, 4.981, 0.929);
            Series1.Add(0.455, 3.445, 0.64);
            Series1.Add(0.88, 1.856, 0.331);
            Series1.Add(0.02, 4.844, 0.789);
            Series1.Add(0.44, 1.724, 0.276);
            Series1.Add(0.736, 5.141, 0.954);
            Series1.Add(0.166, 4.105, 0.71);
            Series1.Add(0.732, 5.121, 0.948);
            //Add valuesi n Series2:
            Series2.Add(0.807, 2.374, 0.469);
            Series2.Add(0.264, 2.173, 0.391);
            Series2.Add(0.856, 3.724, 0.777);
            Series2.Add(0.116, 2.238, 0.403);
            Series2.Add(0.68, 3.676, 0.712);
            Series2.Add(0.112, 6.754, 0.958);
            Series2.Add(0.486, 5.309, 0.882);
            Series2.Add(0.567, 5.171, 0.888);
            Series2.Add(0.193, 1.437, 0.181);
            Series2.Add(0.54, 1.05, 0.024);
            Series1.Brush.Gradient.Visible = false;
            tChart1.ShowEditor();
        private void checkBox1_CheckedChanged(object sender, EventArgs e)
            teeOpenGL1.Active = checkBox1.Checked;
Could you please, tell us previous code works as you expect? If you have any problems please let me know.
JonM
Post by JonM » Mon Aug 20, 2012 1:58 pm
Hi Sandra
Thanks for this I was not aware Tchart had OpenGL.
I tried adding the OpenGl component to my project, but this on run would crash the program with an Object reference. I then went back and looked at your project you sent me. This looked like a standard VCL project so I created a new .Net VCL project and duplicated your code. When I run the project and click on the OpenGL button the program stops with an ‘Object reference not set to an Instance of an object’ message. Does the OpenGL not work with .Net VCL projects ? I am running Version 8.08 of Tchart.
My code is below, I have changed the points so they are easier to see.
Thanks Frank
unit Unit1;
interface
uses
  Dialogs, TeEngine, System.ComponentModel, Borland.Vcl.ExtCtrls, TeeProcs,
  Chart, TeeComma, TeeOpenGL, TeeTriSurface, TeePoin3, Borland.Vcl.StdCtrls;
type
  TForm1 = class(TForm)
    Chart1: TChart;
    TeeOpenGL1: TTeeOpenGL;
    Panel1: TPanel;
    CheckBox1: TCheckBox;
    TeeCommander1: TTeeCommander;
    procedure CheckBox1Click(Sender: TObject);
  private
    { Private declarations }
    Series1:TTriSurfaceSeries;
    Series2:TPoint3DSeries;
  public
    { Public declarations }
  Form1: TForm1;
implementation
{$R *.nfm}
procedure TForm1.CheckBox1Click(Sender: TObject);
  TeeOpenGL1.Active:= CheckBox1.Checked;
  Series1.Transparency:= 20;
  if TeeOpenGL1.Active then
    Chart1.Aspect.Rotation := 359;
    Chart1.Aspect.Elevation:= 359;
  end
//Add Series:
Series2 := TPoint3DSeries.Create(self);
Series1 := TTriSurfaceSeries.Create(self);
Chart1.AddSeries(Series2);
Chart1.AddSeries(Series1);
//             Sw, Ht, Phi
Series1.AddXYZ(1.0,0.0,0.1);
Series1.AddXYZ(0.9,2.0,0.1);
Series1.AddXYZ(0.8,6.0,0.1);
Series1.AddXYZ(0.6,12.0,0.1);
Series1.AddXYZ(0.4,25.0,0.1);
Series1.AddXYZ(1.0,0.0,0.15);
Series1.AddXYZ(0.9,3.0,0.15);
Series1.AddXYZ(0.8,8.0,0.15);
Series1.AddXYZ(0.6,18.0,0.15);
Series1.AddXYZ(0.4,35.0,0.15);
Series1.AddXYZ(1.0,0.0,0.2);
Series1.AddXYZ(0.9,10.0,0.2);
Series1.AddXYZ(0.8,25.0,0.2);
Series1.AddXYZ(0.6,50.0,0.2);
Series1.AddXYZ(0.4,100.0,0.2);
//Add values in Series2:
Series2.AddXYZ(0.6,5.0,0.15);
Series2.AddXYZ(0.6,40.0,0.15);
Series1.Transparency := 20;
end.
Reason: code format
JonM
Post by JonM » Tue Aug 21, 2012 9:50 am
We have look into this problem a bit more and find that when the Transparency is set to zero then the OpenGL works.
With the code in the debugger the problem is in the TeeGLCanvas.pas unit function
Function TGLCanvas.BeginBlending(const R:TRect; Transparency:TTeeTransparency):TTeeBlend;
  if Transparency>0 then
    glEnable(GL_BLEND);
    glBlendFunc(GL_SRC_ALPHA,GL_ONE_MINUS_SRC_ALPHA);
  ITransp:=(100-Transparency)*0.01;
  result:=nil;
This function always returns ‘nil’, which then causes an object reference in the routine calling this ‘TCustomTriSurfaceSeries.DrawAllValues’.
Frank
Reason: code formatting
Post by Yeray » Tue Aug 21, 2012 1:35 pm
I'm afraid this is a known issue already in the wish list to be revised (TV52015900)
http://www.teechart.net/support/viewtop ... =3&t=12815
I've incremented the item severity.
