Modifying lines colors in TDBChart
WarmBooter
Post by WarmBooter » Thu Jul 12, 2012 5:50 pm
Hi!
I have a TDBChart with a Lines series, and I would like to try different color palletes to find the best one (read, the one that repeats less colors) to be used with the situation when the datasource returns several records (meaning more than 15 lines in the chart).
I tried to use DBChart1.ColorPaletteIndex:=<<some existing index>> but seems to produce no effect at all.
Can someone point me to the correct way of doing this?
Carlos
Re: Modifying lines colors in TDBChart
Post by Yeray » Fri Jul 13, 2012 3:17 pm
Hola Carlos,
Take a look at the example at "All Features\Welcome !\Aspect\Custom Palettes" in the features demo included with the installation. It shows how to change between the different default palettes and how to create a customized one.
However, the default palettes (and any you can create) have a limited size. If you want to create more series than colors your palette has, you will probably want to reuse the colors in the palette. You could do so as in the following example:
uses Series;
var i: Integer;
  Chart1.View3D:=false;
  ColorPalettes.ApplyPalette(Chart1, WindowsVistaPalette);
  for i:=0 to 20 do
    with Chart1.AddSeries(TFastLineSeries) do
      FillSampleValues;
      Color:=Chart1.ColorPalette[i mod Length(Chart1.ColorPalette)-1];
