There is some issue I am facing with Legend scroll bar, which I want to share with you. I am using ActiveX TeechartX7 while I am trying to add Legend scrollbar and try to set its property it show error dialog.
Code written to add Legend scroll bar is as follows:
m_chart1.GetTools().Add(tcLegendScrollBar);
m_chart1.GetTools().GetItems(0).GetAsLegendScrollBar().SetDrawStyle(dsWhenNeeded);
It would be very kind of you if you could suggest me with a better option to do so.
Amol
Legend scroll bar issue
Re: Legend scroll bar issue
Hello amol,
I am afraid I can not reproduce your problem here, please can you made a simple project we run as-is here because we can try to find a solution for your problem?
Hello Sandra
i send you demo project please go through it.
when I am trying to add Legend scrollbar and try to set its property it show error dialog "Not Implemented"
i am using ActiveX7 teechart.
it would be very kind of you if you could suggest me with a better option to do so.
Amol
Amol
- LegendScrollBar_AxisIssue_add_legend_ scrollbartool.rar
- (275.43 KiB) Downloaded 938 times
Hello Amol,
Sorry for the delay. We have done many test with your code in last version 7 and in last version 2012 and in last version 2012 your problem doesn't appear,therefore your problem is solved in last version of TeeChartActivex2012. I recommend you check if your problem appears for you with last version using Evaluation version that you can download here.
