How to refresh chart once 'chart area' is draged?
I am plotting a report chart based on some filteration,chart is plotting correctly but when i dragged on chart area toward right side my chart cruves(Line series) and axes data (y primary and y secondary) is changed(which is fine) but when i change my filteration its seems my chart is not refeshing properlly.(may be its saving somewhere in cache the previous draged status...not know).
I am using TeeChart.Silverlight(4.1.2012.1033)
I have tried with - 1:tChart.AutoRepaint = false;,tChart.AutoRepaint = true;
2 tChart.Invalidate() 3: TeeChart.DataContext = null;
but its not wroked for me.
Satyendra
How to refesh chart once 'chart area' is draged?
Re: How to refesh chart once 'chart area' is draged?
Hello Neelam,
As I told you in this thread you can use to redraw the chart, the property of MainPage Visibiblity and set it to Visible as do in next lines of code:
So, I think you can use this property every time you need to redraw the chart. Can you confirm us if it solve your problem?
//Add it to redraw
this.Visibility = System.Windows.Visibility.Visible;
Thanks for yr reply.
Its seems you have not understand the actual issue.i am attaching a file pls refer for more brief on issue.
I dont want to redraw the chart.
Satyendra
Satyendra
- ChartDraggedIssue.rar
- Chart dragged issue brief
- (224.26 KiB) Downloaded 1038 times
Hello Neelam,
Thanks for extra information. I have made a simple code where I am initializing the chart every time I am changing the scenario and I think you can use to achieve as you want.
Can you tell if it works as you expect?
Steema.TeeChart.Silverlight.Styles.Line Series1, Series2;
public MainPage()
//Series
//comboBox
this.comboBox1.Items.Add("Scenario A");
this.comboBox1.Items.Add("Scenario B");
this.comboBox1.SelectedIndex = 0;
this.comboBox1.SelectedItem = 0;
comboBox1.SelectionChanged +=new SelectionChangedEventHandler(comboBox1_SelectionChanged);
// comboBox1
Scrolling();
void comboBox1_SelectionChanged(object sender, SelectionChangedEventArgs e)
switch(comboBox1.SelectedIndex)
case 0:
tChart1.Clear();
Scrolling();
break;
case 1:
tChart1.Clear();
Series1 = new Steema.TeeChart.Silverlight.Styles.Line(tChart1.Chart);
Series1.FillSampleValues();
Scrolling();
break;
Series2 = new Steema.TeeChart.Silverlight.Styles.Line(tChart1.Chart);
Series1.Add(0, 0.05);
Series1.Add(1, 0.1);
Series1.Add(2, 0.15);
Series1.Add(3, 0.2);
Series1.Add(4, 0.25);
Series1.Add(5, 0.30);
Series1.VertAxis = VerticalAxis.Left;
Series2.Add(0, 35);
Series2.Add(1, 20);
Series2.Add(2, 150);
Series2.Add(3, 98);
Series2.Add(4, 75);
Series2.Add(5, 120);
Series1.VertAxis = Steema.TeeChart.Silverlight.Styles.VerticalAxis.Left;
tChart1.Axes.Right.Visible = true;
Series2.VertAxis = Steema.TeeChart.Silverlight.Styles.VerticalAxis.Right;
private void Scrolling()
tChart1.Zoom.Allow = false;
tChart1.Panning.Allow = Steema.TeeChart.Silverlight.ScrollModes.Horizontal;
tChart1.Panning.MouseButton = System.Windows.Browser.MouseButtons.Left;
