decimals on axis
Werner
decimals on axis
Post by Werner » Mon May 21, 2012 11:47 am
I use Tchart 8 professional.
I set the decimal to a fix one e.g LeftAxis.AxisValuesFormat:=0.0
If I zoom the axisvalue is always the same : for e.g. 1.1/1.1/1.1
So what can I do, that the format changes so that the last digit is different.
Example : I zoom -> the axis is 1.11/1.12/1.13
I zoom more the axis is 1.111/1.112/1.113 and so on
with best regards
Werner
Re: decimals on axis
Post by Yeray » Tue May 22, 2012 2:12 pm
Hi Werner,
By default, the AxisValuesFormat is '#.##0,###'. But you can change it as you want adding more decimals if you need them.
You even could calculate the string in the OnZoom event to add more or less decimals. It could be something similar to this:
var Range: Double;
    i: Integer;
    valueFormat: String;
  Range:=(Chart1.Axes.Bottom.Maximum-Chart1.Axes.Bottom.Minimum);
  Chart1.Draw;
  valueFormat:='#,##0.#';
  i:=1;
  while ((Range / Chart1.Axes.Bottom.Items.Count) * (i*10) < 1) do
    Inc(i);
    valueFormat:=valueFormat+'#';
  Chart1.Axes.Bottom.AxisValuesFormat:=valueFormat;
