TBarSeries Bottom Axis - Missing Labels
A44508
Post by A44508 » Mon May 14, 2012 7:20 am
Initially, some of the labels on the bottom axis were not displayed due to what I suspect is insufficient space.
But the missing labels were still not displayed when the Chart1.BottomAxis.LabelsAngle was set to 45 degrees.
The screen shows plenty of space available after the LabelsAngle was adjusted.
Any explanation for the strange behaviour and a way to fix the problem?
I am using TeeChart v7 with Dephi 7
Bye,
Wan Yee
Re: TBarSeries Bottom Axis - Missing Labels
Post by Yeray » Mon May 14, 2012 3:22 pm
Hi Wan Lee,
Have you tried with LabelsAngle = 90?
When LabelsAngle is oblique, the distance between labels is calculated as if LabelsAngle were 0. I've added it to the wish list to be enhanced (TV52016186).
A44508
Post by A44508 » Tue May 15, 2012 12:21 am
Thanks! It works now with LabelsAngle set to 90.
Bye,
Wan Yee
