Series: Assigning different horizontal axis
I would like to assign different horizontal axes (bottom, top, or both) to series. Using the example Welcome !\Chart styles\Statistical\Box-Plot, and assigning Series1 the bottom, Series2 the top and Series 3 both horizontal axes, series 1 and 2 will overlap. It seems that will happen only if one series is assigned to both axes. However, series are switched in position if horizontal axis is changed between bottom and top.
Oli
Oli
Re: Series: Assigning different horizontal axis
Hello Oli,
I can not reproduce your problem using the sample of Demo Project Box-Plot and last maintenance release 4.1.2012.02280 TeeChart.Net. Could you please, send us a simple project where the problem occurs so we can try to solve it?
Hi Sandra,
attached a project file demonstrating the problem. I have found other problems, such as changing line style of the Medianline in boxplots after saving/loading from binary format, and inverting the x axis. An old problem still persisting is the overlapping controls of the editor. I remember that on your machine you could reproduce it neither, and I am concern that something on my machines causes some weird behavior. I would appreciate if you can test the attached demo project, and see if you can reproduce similar behavior. I have attached pictures of what I see on my machine.
Thanks Oli
Thanks Oli
- Inverted x axis
- BoxOnInvertedAxis.PNG (46.2 KiB) Viewed 24616 times
- Assigning top axis
- BoxAssigningTopAxis.PNG (40.03 KiB) Viewed 24595 times
- TChartproject.zip
- Demo
- (222.55 KiB) Downloaded 1472 times
Hello Oli,
Thanks for your project. Can you try to arrange a simple code without Dewresearch component, so we can reproduce exactly problem here and try to find a solution?
Hi Sandra,
sorry for the implementation of the DewResearch component. Attached a demo project without DewResearch. Since I got the same effect with your demo program, I am getting concerns that some of the "strange" behavior is machine-specific. For example also the overlapping controls in the editor I reported some time ago. Below my computer configuration in case it helps to locate the problem:
Oli
Opertaing system
Name : Microsoft Windows 7 Home Premium (German version)
Platform : Win32NT
Edition : 6.1.7600.0
Directory : C:\Windows
Status : OK
Memory
Physical, total : 3220561920
Physical, available : 1456013312
Virtual, total : 2147352576
Virtual, available : 1751621632
Motherboard
Manufacturer : MICRO-STAR INT'L CO., LTD
Product : MS-1731
Processor : Intel(R) Core(TM)2 Duo CPU T6600 @ 2.20 Ghz
Status : OK
BIOS
Manufacturer : American Megatrends Inc.
Version : ?
Status : OK
Video Controller
Name : ATI Mobility Radeon HD 4330
Processor : ATI display adapter (0x9552)
Adapter RAM : 536870912
Status : OK
Screen
Width : 1600
Height : 900
Country, specific
Country : English (United States)
Keyboard ID : 1033
Oli
Opertaing system
Platform : Win32NT
Status : OK
Memory
Motherboard
Product : MS-1731
Status : OK
BIOS
Version : ?
Status : OK
Video Controller
Status : OK
Screen
Width : 1600
Height : 900
Country, specific
Keyboard ID : 1033
- tchartproject.zip
- (226.33 KiB) Downloaded 1421 times
Hello Oli,
If you want work with editor, you must change manually the minimum and maximum of axis.
Ok. I can reproduce your problem and I have added it in bug list report[TF02016181]. We will try to fix it for next maintenance releases of TeeChart.Net.1. Problem: Inverted x axis. If x axis gets inverted, the boxes become offset to the errorbars (whiskers).
I have added this problem as a bug in bug list report with number [TF02016183]. We will try to fix it for next maintenance releases of TeeChart.Net.2. Problem: Save/Load in native binary teechart format Click "Save" Click "Load" Style of median line changes to dashed.
This is not a bug. If you assign a series to different axis, for default the scale of axis recalculate the values and set new values to Axis. In your case when you change the Horizaxis of one of your Bloxplot series, the minimum and maxim are 0 or have a different scale of Bottom Axis. For this reason I recommend you set the same scale for top axis and bottom axis as do in next line of code:3. Assigning a Series to top axis
Assign first series to top axis (through editor), and it will
disappear...at least on my machine
boxplot1.HorizAxis = HorizontalAxis.Top;
tChart1.Axes.Bottom.SetMinMax(0, 2);
tChart1.Axes.Top.SetMinMax(0, 2);
Can you tell me how we can reproduce this problem?4. Editor
Some controls overlapping each other
Hi Sandra,
Thanks for fixing the bugs.
Regarding the editor, we have discussed it earlier at http://www.teechart.net/support/viewtop ... oli#p56550
I have attached another screenshot of how the editor is display on my computer. I use the following code :
Dim editor1 As Steema.TeeChart.Editor = New Steema.TeeChart.Editor(tChartBoxPlot)
editor1.Width = Convert.ToInt32(800)
editor1.Height = Convert.ToInt32(500)
editor1.ShowModal()
It could possibly be a computer-specific problem, and I will change to a new computer next month. I keep you updated if this problem persist on the new computer.
Cheers
Oliver
editor1.ShowModal()
Cheers
Oliver
- Editor_OverlappingControls.PNG (63.8 KiB) Viewed 24548 times
Hello Oli,
As I said in the thread we cannot reproduce your problem here with our machines and using your code I have gotten next results: When you have made the test with other machine, please tell us the results.
Hi Sandra,
that is an older post regarding the editor. On my new machine the editor looks just fine, so it was a machine-specific problem. However, I could not figure out how to solve it on my old machine. Just for your information.
Oli
Oli
Hi Oli,
It could be something related to the machine's resolution and/or the font size. Have you tried changing it?
I think I changed the screen resolution but without solving the problem...sorry it ís now a couple of months ago. It is not a problem for me as I designed my own editor. Not because of the problem I encountered, but simply I did not require all the settings and options in the editor and there are too many levels of tabs in the Steema editor. However, I understand that you want to implement many controls in your editor to serve many users with this features, and it simply requires multiple levels of tabs. I just wanted it better designed to my application, so I did my own editor.
Cheers
Oli
Cheers
Oli
Hi Oli,
Many thanks for information.
