activate context error in TeeGlCanvas
jls
Post by jls » Mon Apr 16, 2012 10:03 am
I try to run the sample PieDemo.zip
http://www.teechart.net/support/viewtop ... 107#p52331
it gives the error activate context error in TeeGlCanvas.
Any reason?
Re: activate context error in TeeGlCanvas
Post by Yeray » Mon Apr 16, 2012 10:25 am
What IDE and TeeChart version are you using?
jls
Post by jls » Mon Apr 16, 2012 11:15 am
XE
Teexchart V 2011.04
Post by Yeray » Tue Apr 17, 2012 9:15 am
Using TeeChart Pro v2011.04 with Rad XE, I just had to download the FastMM4 lib from here and reference it in the project.
Then, it compiles an can be executed normally. Actually, the application seems not to respond unless I press the "Edit 3D..." button, that seems to wake it up. But I'm not able to reproduce any "activate context error in TeeGlCanvas"
Regarding what you said here:
jls wrote:the demo
viewtopic.php?f=3&t=11921&p=51107#p52331
dosn't work
1) access violation designtime
2)stack overflow runtime (it compiles)
Please, try to write step-by-step instructions we should follow to reproduce the errors.
