Hello
TeeChart2011.04.41118+BDS2006
with following project, whenever I move the mouse over the TChart, there will be access violation unless I disable the TMarkTools, or the series is not empty.
Steps:
1. Drop a TChart to the Form
2. Double click the Chart, and add an AreaSeries at design time
3. Double click the chart, and add a TMarkTool
4. in Form OnCreate event, have following code:
AreaSeries: TAreaSeries;
AreaSeries:=TAreaSeries.Create(Self);
AreaSeries.ParentChart :=Chart1;
AreaSeries.FillSampleValues(5);
AreaSeries.Marks.Visible :=False;
AreaSeries.LinePen.Visible :=False;
AreaSeries.AreaLinesPen.Visible := False;
AreaSeries.LinePen.Visible := False;
AreaSeries.MultiArea := maStacked;
Run the application, and move the mouse, then you will have access violation error.
The reason for an empty series at step2 is that in the real situation, the series are linked to a source of TDataSet, who might be empty, where the problem is actually happened.
Detail please find in attachment. It contain the source code and also the exception call stack caught by Eurekalog.
TMarkTools causes Access Violation Error if Series is empty
- bug.zip
- (13.26 KiB) Downloaded 336 times
Re: TMarkTools causes Access Violation Error if Series is empty
I could reproduce it and found where the problem was. I've fixed it for the next maintenance release (TV52016025).
When the update will be released?
We have to deliver our SW by the end of Feb. Can we have the update of TeeChart by then?
I don't think we'll publish a maintenance release this month. However, as the fix is simple, if you are source code customer you can apply it yourself.
The line 1653 in Series.pas says:
Change it for:
If you are not a source code customer, just tell us and we'll study if we can prepare a release for you.
if (Index>=tmpFirst) and ClickableLine then
if (Index>tmpFirst) and ClickableLine then
bug solved.
