X axis labels issue with multiple series
HHYen
Post by HHYen » Fri Jan 20, 2012 6:40 am
Hello.
We upgrade tee chart from TeeChart2010.0.0.3ActiveX to TeeChart2011.0.0.4ActiveX.
Please take a look at the following pictures.
The x axis lables are in a mess.
2010.png : TeeChart2010.0.0.3ActiveX
2011.png : TeeChart2011.0.0.4ActiveX
Can you tell me how to fix this ?
Re: X axis labels issue with multiple series
Post by Yeray » Mon Jan 23, 2012 8:29 am
Hi HHYen,
Can you please give a try to the recently published v2011.0.0.5?
The problem you found looks the same discussed here
HHYen
Post by HHYen » Mon Jan 30, 2012 2:27 am
We've tried v2011.0.0.5.
It seems nothing change to me.
The X axis label are still in a mess.
Any idea ???
Post by Yeray » Mon Jan 30, 2012 10:56 am
Then I'm afraid I'll have to ask you for a simple example project we can run as-is to reproduce the problem here.
HHYen
Post by HHYen » Tue Jan 31, 2012 2:41 am
Here you are.
XaxisProblem.zip
Sample code.
(251.7 KiB) Downloaded 1080 times
Post by Yeray » Tue Jan 31, 2012 11:35 am
What about forcing the bottom axis to show the values instead of the labels?
tChart.Axis.Bottom.Labels.Style = EAxisLabelStyle.talValue;
Alternatively, the latest version where this changed in AX was with v2011.04, so with v2010.03 the problem that is affecting you wasn't reproducible (problem #1 mentioned here).
HHYen
Post by HHYen » Wed Feb 01, 2012 9:11 am
Hello.
Thanks for your help.
Line chart is ok with
As for point chart. Value is no meaning for us. We would like to show text in X axis label.
2010 version is no problem.
2011 version is not good for me.
any idea ?
XaxisProblem2.zip
(216.18 KiB) Downloaded 1035 times
Post by Yeray » Wed Feb 01, 2012 10:27 am
With v2011.0.0.4 or v2011.0.0.5, the only solutions I see:
- Only add one series with labels. In your example, if I change the second series loop for this, it seems to work fine:
            for (int i = 0; i < 50; i++)
                iSeries.AddXY(i + 0.5, 2, /*"second" + i*/ "", 0x0000ff);
- Use custom labels instead of letting talText to draw all the labels of all the series. Adding this at the end of your Main method (just before exporting the chart to png) it seems to work fine:
            tChart.Environment.InternalRepaint();
            int lastpos = 0;
            tChart.Axis.Bottom.Labels.Clear();
            for (int i = 0; i < tChart.Series(0).Count; i++)
                if ((lastpos == 0) || (tChart.Axis.Bottom.CalcXPosValue(tChart.Series(0).XValues.Value[i]) - lastpos > 10))
                    tChart.Axis.Bottom.Labels.Add(tChart.Series(0).XValues.Value[i], tChart.Series(0).PointLabel[i]);
                    lastpos = tChart.Axis.Bottom.CalcXPosValue(tChart.Series(0).XValues.Value[i]);
HHYen
Post by HHYen » Thu Feb 02, 2012 3:58 am
I have no further questions.
Post by Yeray » Thu Feb 02, 2012 9:46 am
You are welcome! :)
