Scaling plots
johnnix
Scaling plots
Post by johnnix » Wed Dec 14, 2011 9:49 am
In my application I use Picture objects to present my plots inside my FastReports pages. Currently I am investigating the possibility to present plots in a fixed Y-axis scale for example every 1 cm on the plot will reflect 1 meter in real life (for a plot where the Y axis represents a distance measurement). Any ideas, hints or tips would be mostly appreciated :D
Kindest regards
Re: Scaling plots
Post by Yeray » Thu Dec 15, 2011 3:55 pm
Hi johnnix,
A cm on the screen depends on the screen resolution. GetDeviceCaps gives you the width and height of the screen so you can use it to calculate the chart size.
Take a look at the "All features\Welcome !\Axes\Isometric Axis" example in the features demo to see how this function is used in it.
johnnix
Re: Scaling plots
Post by johnnix » Fri Dec 16, 2011 7:17 am
Hello Yeray,
Thank you for your tip but I know how to use the GetDeviceCaps but let me explain my question a little bit more. I can calculate that X pixels on the screen form a real cm, how can I transfer this to my plot so that the distance between major marks is X pixels? Or how can I draw the plot in such a way that the size of an axis equals specific pixels?
Re: Scaling plots
Post by Yeray » Mon Dec 19, 2011 1:31 pm
Hi johnnix,
johnnix wrote:Or how can I draw the plot in such a way that the size of an axis equals specific pixels?
You can assign a ChartRect with a specific pixel size. However, note this ChartRect set, includes the space for the labels, titles, etc. So you should calculate the space this things will take and add it as extra space. Here it is a simple example of how you could force a ChartRect:
uses Series;
const myWidth=200;
      myHeight=200;
var horizOffset, vertOffset: Integer;
  Chart1.View3D:=false;
  Chart1.AddSeries(TFastLineSeries).FillSampleValues();
  Chart1.CustomChartRect:=true;
  Chart1.Legend.Visible:=false;
  Chart1.Draw; //just to have a valid MaxLabelsWidth value
  horizOffset:=6;
  horizOffset:=horizOffset+Chart1.Axes.Left.MaxLabelsWidth;
  horizOffset:=horizOffset+Chart1.Axes.Left.TickLength;
  vertOffset:=6;
  vertOffset:=vertOffset+Chart1.Title.Height;
  vertOffset:=vertOffset+Chart1.Axes.Bottom.LabelHeight(0);
  vertOffset:=vertOffset+Chart1.Axes.Bottom.TickLength;
  Chart1.ChartRect:=Rect(0, 0, horizOffset+200, vertOffset+200);
var tmpRight, tmpTop: Integer;
  //drawing the desired chart rect
  Chart1.Canvas.Brush.Style:=bsClear;
  Chart1.Canvas.Pen.Color:=clRed;
  tmpRight:=Chart1.Axes.Left.PosAxis;
  tmpTop:=Chart1.Axes.Left.IStartPos;
  Chart1.Canvas.Rectangle(Rect(tmpRight, tmpTop, tmpRight+myWidth, tmpTop+myHeight));
