TeeChart Pro for XE2 pre-release sourcecode installer crashs
Bill
Post by Bill » Tue Oct 04, 2011 8:50 pm
The installer crashes during the installation, after the pass code is entered.
-Bill
Re: TeeChart Pro for XE2 pre-release sourcecode installer crashs
Post by Yeray » Thu Oct 06, 2011 8:05 am
Hello Bill,
It works fine for me here in a Win7 x64.
What OS are you running? Does the installer give you any error message? Are you running it with high privileges?
Bill
Post by Bill » Thu Oct 06, 2011 12:00 pm
I'm running win32 XP pro. I've tried on another machine and got the same issue.
Bill
Post by Bill » Thu Oct 06, 2011 12:10 pm
It crashes after Select Internet connection method dialog. The next dialog is the Directory dialog. If I do nothing for 5 seconds. The Microsoft Send Error report dialog will show up and saing TeeChart Pro 2011 Source Code has encountered a problem and needs to close.
Post by Yeray » Fri Oct 07, 2011 11:49 am
Hello Bill,
Could you please try downloading the installer again (in case your copy got corrupted).
Did the older installers work fine in these computers?
I suspect it could be something related to your internet connection because we've tried it in several machines here and found no problems. You choose "Direct connect to Internet" option?
Bill
Post by Bill » Fri Oct 07, 2011 1:03 pm
OK. I've just tried on another machine and it worked fine. The issue may have to do with McAFee. I'll look into that. Sorry for the problems.
-Bill
Post by Yeray » Fri Oct 07, 2011 2:26 pm
Hello Bill,
I'm glad to hear you found the cause of the problem.
Try disabling the antivirus during the installation so it can access the registry.
