Bad position for line series labels
tenaris
Post by tenaris » Thu Jun 30, 2011 5:26 pm
Hi, we have a project in .net WPF with TChart WPF. We're trying to put labels on each series, but shifting and zooming into the graph, the labels are not positioned correctly. The value of each label is the title of the series, used to set marks with MarksStyles.SeriesTitle.
There are 3 pictures. The firts, is ok, when the window is loaded. The second, after a shift (note the incorrect positioning of labels). The third, after a zoom, the labels completely disappear.
I've tried setting custom mark position and using annotations also, but in both cases the positions were wrong. Thre is a simple way to fix this problem?
Pictures.zip
Pics
(66.75 KiB) Downloaded 483 times
Re: Bad position for line series labels
Post by Narcís » Fri Jul 01, 2011 10:14 am
Hi tenaris,
Probably there's but to be able to give an accurate reply we need to see how this chart is created. Can you please attach a simple example project we can run "as-is" to reproduce the problem here?
tenaris
Post by tenaris » Fri Jul 01, 2011 8:30 pm
Thanks Narcís for your reply. We resolved this issue by fixing our code. The bug was while trying to get close the marks with the series, using the GetSeriesMark event and setting custom position to true. Marks positions now are correctly placed and zoom is working properly.
best regards.
Post by Sandra » Mon Jul 04, 2011 7:46 am
Hello tenaris,
I am glad that you can find a solution of your problem :).
