I am switching from TeeChart Pro v7.0.0.7 to TeeChart .Net Pro v.4.0.2011.2082. I want to disable some options provided by “ChartController”. e.g. “Add”, “Delete”, “Title”, “Clone” and “Change” buttons for series tab on run time (through code). In TeeChart7 I was doing the same by using Editor using following code
TeeCommander1.EditorLink = TeeEditor1.EditorLink
TeeEditor1.Options.Add = False
How I can perform same functionality in TeeChart for .Net 2010?
Thanks and Regards,
Immi
How to disable options of ChartController on run time?
- Newbie
Re: How to disable options of ChartController on run time?
Hello Maverick123,
I recommend you, take a look in demo project, concretely in All Features\Welcome!\Components\ChartController\ChartController Editor where you can see how you can customizing your ChartController.
- Newbie
Sandra,
Thanks for reply,
In Demo project i got the way to hide whole tab(s). Even if i can hide buttons through "ChartEditorOptions" it will not solve my problem because i want to Disable buttons (not hide) as were done in TeeChart7.
I am repeating my question: How can I disable “Add”, “Delete”, “Title” etc buttons on series tab of ChartController in TeeChart for .Net 2010? I will appreciate of you can provide me a sample code for this.
Maverick
Thanks for reply,
Maverick
Hi Maverick,
You need to do as Yeray explained here. So that in your case would be:
Steema.TeeChart.Editor editor = new Steema.TeeChart.Editor(tChart1);
Steema.TeeChart.Editors.ChartEditorOptions[] options = new Steema.TeeChart.Editors.ChartEditorOptions[2] {
Steema.TeeChart.Editors.ChartEditorOptions.Clone,
Steema.TeeChart.Editors.ChartEditorOptions.Change };
editor.Options = options;
editor.ShowModal();
- Newbie
Hello Narcis,
Thanks a lot for your reply,
I think you are not getting my point although i tried to explain clearly in my last reply. i.e.
The code you provided is hiding the buttons/options not disabling.
In order to explain more clearly i am attaching a document having print shots of, what i am looking for and what sample code is doing.
Hope it works,
I have another question. In TeeChart7 i copied the graph into clipboard by using following code
TChart1.Export.CopyToClipboardMetafile(True)
What is the alternate of "CopyToClipboardMetafile" in .Net version of TeeChart. OR How i can achieve the previous functionlaity in through .Net version of TeeChart.
Hope you will not mind my 2nd question in reply of the first one
Maverick
Hope it works,
Maverick
- TeeChart.zip
- Doc file explaining my problem.
- (35.01 KiB) Downloaded 322 times
Hi Maverick,
Sorry, I see what you mean now. I'm afraid this is not possible, only toggling them is possible for now. I'll add your request to the wish-list to be considered for inclusion in future releases (TF02015635).The code you provided is hiding the buttons/options not disabling.
There's an example of this at All Features\Welcome !\Exporting\Chart Picture\Metafile example in the features demo available at TeeChart's program group.What is the alternate of "CopyToClipboardMetafile" in .Net version of TeeChart. OR How i can achieve the previous functionlaity in through .Net version of TeeChart.
