Select and Delete Annotation Rectangle
lilo
Post by lilo » Sun Jun 05, 2011 2:20 am
What is the best to select and delete annotation rectangle already placed on a chart?
Re: Select and Delete Annotation Rectangle
Post by Sandra » Mon Jun 06, 2011 9:19 am
Hello lilo,
Can you explain exactly, step to step, what do you achieve that annotation do in your application?
Post by Yeray » Mon Jun 06, 2011 9:32 am
Hello lilo,
If what you want is to select an annotation clicking over it and remove it with, for example, the "Supr" key, you could use the Selector Tool and the events as follows:
        private Steema.TeeChart.Tools.Selector sel1;
            sel1 = new Steema.TeeChart.Tools.Selector(tChart1.Chart);
            Steema.TeeChart.Tools.Annotation annot = new Steema.TeeChart.Tools.Annotation(tChart1.Chart);
            annot.Left = 100;
            annot.Top = 100;
            annot.Text = "Testing annotation";
            Steema.TeeChart.Styles.Bar bar1 = new Steema.TeeChart.Styles.Bar(tChart1.Chart);
            bar1.FillSampleValues();
            tChart1.KeyDown += new KeyEventHandler(tChart1_KeyDown);
        void tChart1_KeyDown(object sender, KeyEventArgs e)
            if ((sel1.Selection is Steema.TeeChart.Tools.Annotation) && (e.KeyData == Keys.Delete))
                tChart1.Tools.Remove(sel1.Selection as Steema.TeeChart.Tools.Annotation);
lilo
Post by lilo » Mon Jun 06, 2011 1:31 pm
Thanks Yeray, That's what I want to do.
