Exporting date data to excel
When I export a chart to Excel, values are exported in X & Y, how can I customize the column headers? How can I add rows at the beginning to place information? What can I keep the date-type format because date data are exported as numbers?
Re: Exporting date data to excel
Hello JAV,
Some of this has been discussed here
Here is an example:
Here is an example:
Private Sub Form_Load()
TChart1.Aspect.View3D = False
TChart1.AddSeries scLine
TChart1.Series(0).XValues.DateTime = True
Dim month, year, i As Integer
i = 0
For year = 2003 To 2009
For month = 1 To 12
TChart1.Series(0).AddXY DateValue("1/" & Str$(month) & "/" & Str$(year)), Sin(i / 10), "", clTeeColor
i = i + 1
Next month
Next year
TChart1.Series(0).Title = "Series title"
TChart1.Series(0).XValues.Name = "X Values"
TChart1.Series(0).YValues.Name = "Y Values"
With TChart1.Export.asText
.IncludeHeader = True
.IncludeIndex = True
.SaveToFile "C:\tmp\test1.xls"
End With
With TChart1.Export.asXLS
.SaveToFile "C:\tmp\test2.xls"
End With
I'm afraid it's not possible right now. I've added it to the wish list to be implemented in future releases (TV52015584).JAV wrote:How can I add rows at the beginning to place information?
Hello Yeray:
I reviewed the demo and I've searched in the forum but I cannot export to excel as a date format, it continues exporting as a number (See attached file Fecha_Ventas.jpg)
I am using the following code with TeeChart8.ocx:
Additionally, now I have a new problem: I have three series referring to the x and y axis (left), and one serie with the x and y axis (right). All series in the same chart. The 3 axes are numerical (bottom, right, left); when I exported to excel only the y-axis coordinates are exported, how can I export the x-axis values? (See attached file 2_ejes_y.jpg)
Best regards,
JAV
tChart1:Series(0):VerticalAxis = 0.
tChart1:Series(0):XValues:DateTime = TRUE.
tChart1:Series(0):XValues:NAME = "Fecha".
tChart1:Series(0):YValues:NAME = "Valor total".
FOR EACH ventas:
tChart1:Series(0):ADDXY(ventas.fecha, ventas.valor_total, “ “, 0).
END:
tChart1:Axis:Bottom:Visible = TRUE.
tChart1:Axis:Bottom:Automatic = TRUE.
tChart1:Axis:Bottom:Title:Caption = "Fecha".
tChart1:Axis:RIGHT:Visible = TRUE.
tChart1:Axis:RIGHT:Automatic = TRUE.
tChart1:Axis:RIGHT:Title:Caption = "Total".
tChart1:Axis:Left:VISIBLE = FALSE.
tChart1:Axis:TOP:Visible = FALSE.
tChart1:EXPORT:asXLS:IncludeHeader = TRUE.
tChart1:EXPORT:asXLS:IncludeIndex = FALSE.
tChart1:EXPORT:asXLS:IncludeLabels = TRUE.
tChart1:EXPORT:asXLS:Series.
tChart1:EXPORT:asXLS:SaveToFile ("C:\Temp\Fecha_Ventas.xls").
Best regards,
JAV
- The x-axis isn't exported
- 2_ejes_y.jpg (41.37 KiB) Viewed 17765 times
- First column must be a date format
- Fecha_Ventas.jpg (29.26 KiB) Viewed 17765 times
Hello JAV,
However, if you use the AddXY method to add XValues manually, they seem to be exported correctly for me here:
Have you seen the summary here of the possibilities available?JAV wrote:I reviewed the demo and I've searched in the forum but I cannot export to excel as a date format, it continues exporting as a number (See attached file Fecha_Ventas.jpg)
Have you added XValues? If you use the Add method (so you don't add XValues) the XValues will be 0, 1, 2,... and they won't be exported.JAV wrote:Additionally, now I have a new problem: I have three series referring to the x and y axis (left), and one serie with the x and y axis (right). All series in the same chart. The 3 axes are numerical (bottom, right, left); when I exported to excel only the y-axis coordinates are exported, how can I export the x-axis values? (See attached file 2_ejes_y.jpg)
Dim i As Integer
For i = 0 To 6
With TChart1.Series(i)
.AddXY 0, Rnd * 100, "", clTeeColor
Dim j As Integer
For j = 1 To 20
.AddXY j * i, .YValues.Value(j - 1) + Rnd * 10 - 5, "", clTeeColor
Next j
If i > 2 Then
.VerticalAxis = aRightAxis
End If
End With
Next i
TChart1.Export.asText.SaveToFile "C:\tmp\test.xls"
Indeed, I am using AddXY to generate all series. When X-axis is set as date format, the data is exported correctly, I mean, each serie with their own X and Y value, but if x-axis format is changed to numerical format, the X data is not exported, only Y values.
Please your help, I am getting crazy. I am using TeeChart8.ocx and Excel 2007, just in case...
Hello JAV,
Are the X Values 0, 1, 2,...? If that's the case you could add the indexes:
TChart1.Export.asText.IncludeIndex = True
This solution could work with the longest series but not all the series that we are plotting have the same value on the x-axis or the same amount of data, for example: Series 1 : (1, 89), (2, 56), (3, 90), etc ... and the series 2: (12, 110), (31, 67). Therefore it is necessary to export each serie completed, with data in X and Y.
Thank you very much for your time and support,
JAV
Esta solucion podria funcionar con la serie mas larga o con la serie con mayor cantidad de puntos, pero no ocurre porque las series que estamos graficando no tienen ni los mismos valores en el eje x ni la misma cantidad de datos, por ejemplo: serie 1: (1;89), (2;56), (3;90), etc... y la serie 2: (12;110), (31;67). Por lo tanto es necesario que cada serie se exporte completa, con datos en X y en Y.
Muchisimas gracias por tu tiempo y ayuda. Saludos cordiales,
JAV
JAV
JAV
Hi JAV,
In that case I'm afraid the only solution is exporting each series individually, for example:
I have also added your request (TV52015617) to the wish-list to be considered for inclusion in future releases.
TChart1.Export.asXLS.Series = TChart1.Series(0)
Dear Narcis,
We did what you suggested, we export a serie at once but it didn't work. In this case only one column, Y axis values, was exported.
Just for trying, we increased in 1 each X value of serie 0 and with this change this were successfully exported. Even when exporting all series in the chart with this modification, entire series were exported properly, as shown in the attachment, but column A should be identical to column G, ie it must start at 0. What could be happening? Please note that if serie 0 in X axis starts at 0 we get any column X in every series exported.
Best regards,
JAV
Best regards,
JAV
- Solution.JPG (97.64 KiB) Viewed 17699 times
Hello JAV,
I think the problem is that, when the first series has XValues 0, 1, 2, 3, ..., the XValues aren't exported for any series, even when the other series have different XValues. This possibility will be investigated when the ticket TV52015617 will be addressed.
