I create a Contour Series with my data,but there's no chart shown. Is there anything wrong in my project? The attachment is my application.
Thanks!
Contour Series
Contour Series
- teeChartDemo.rar
- (24.43 KiB) Downloaded 547 times
Re: Contour Series
Anyone could help me?
Re: Contour Series
Hello leihj,
We are currently investigating the issue and will get back to you as soon as we have some news.
Re: Contour Series
Hello leihj,
Such series styles need to be populated as I explained here. I'm afraid your data is too much irregular to form a drawable structure. It works fine for me here using dataset2.xls, which I attach, and this code:
string strConn = "Provider=Microsoft.Jet.OLEDB.4.0;Data Source=C:/temp/teeChartDemo/teeChartDemo/dataset2.xls;" + "Extended Properties='Excel 8.0'";
DataSet ds = new DataSet();
OleDbDataAdapter oada = new OleDbDataAdapter("select * from [Sheet1$]", strConn);
oada.Fill(ds);
Contour contour1 = new Steema.TeeChart.Styles.Contour();
tChart1.Series.Add(contour1);
contour1.DataSource = ds.Tables[0];
contour1.XValues.DataMember = "X";//SPEED";
contour1.YValues.DataMember = "Y";//BMEP";
contour1.ZValues.DataMember = "Z";//P";
- dataset2.zip
- (5.14 KiB) Downloaded 555 times
