Zoom Custom Axis
MikeK
Zoom Custom Axis
Post by MikeK » Thu May 12, 2011 3:41 pm
I have read the link refering to zooming custom axes, but i need some help converting the Delphi code to AxtiveX.
My chart has custom left and bottom axes, because I need the relationship to be a 1:1 ratio since I am plotting a gear tooth profile.
I have written the following code, but do not know how to capture the cursor locations for SetMinMax.
Private Sub AxTChart1_OnZoom(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles AxTChart1.OnZoom
AxTChart1.Axis.Left.SetMinMax()
AxTChart1.Axis.Bottom.SetMinMax()
Instead of using the code above, I have modified the routine as follows.
Dim top As Double
top = AxTChart1.Axis.Left.Minimum + (AxTChart1.Axis.Bottom.Maximum - AxTChart1.Axis.Bottom.Minimum)
AxTChart1.Axis.Left.SetMaximum(top)
The proper values are captured for the size of the zoom window, but when I execute it, nothing happens. I tried adding a Refresh to the routine, but that had no affect.
Zooming is allowed on the chart editor.
Mike
Re: Zoom Custom Axis
Post by Sandra » Fri May 13, 2011 3:23 pm
Hello MikeK,
To achieve cursor location you need use Mouse Events for example OnMouseClick or OnMouseDown or OnMouseMove etc.
Dim top As Double
On the other hand, event OnZoom works fine for me. Please can you arrange a simple project because we can reproduce exactly your problem here?
