Access Cursor selection by code
Petar
Post by Petar » Wed Apr 13, 2011 4:29 pm
I would like to change the cursor type on run time( by using code).
How can I do that, i didn't find anything like "AxTChart.Cursor" or similar?
Petar
Re: Access Cursor selection by code
Post by Sandra » Fri Apr 15, 2011 9:49 am
Hello Petar,
I think you can do something as next lines of code:
TChart1.OriginalCursor = -21
Please, confirm us if previous lines of code works as you expect?
Petar
Post by Petar » Fri Apr 15, 2011 2:39 pm
Thanks Sandra,
in fact in .NET this property does not exists ( instead I used ctlCursor)
Cheers
Petar
Post by Sandra » Mon Apr 18, 2011 8:14 am
Hello Petar,
Could you tell us which version of TeeChartAxtivex are you using now? So in last version of TeeChartActivex and .Net property originalCursor exist as you can check in next lines of code:
    Private Sub Form1_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
        AxTChart1.OriginalCursor = -21
