WPF TChart program hang
neurosoft
Post by neurosoft » Tue Apr 12, 2011 8:37 am
Hello!
With this segment of code program hanged forever. But if use for tChart.Height another value than 63 it works.
The problem is in method Steema.TeeChart.WPF.Axis.InternalCalcLabelsIncrement() - there is some infinite cycle.
public partial class MainWindow : Window
public MainWindow()
TChart tChart = new TChart();
Points points = new Points();
tChart.Axes.Left.AutomaticMaximum = false;
tChart.Axes.Left.AutomaticMinimum = false;
tChart.Axes.Left.Logarithmic = true;
tChart.Axes.Left.Maximum = 100;
tChart.Axes.Left.Minimum = 10;
tChart.Series.Add(points);
tChart.Width = 300;
tChart.Height = 63;
Content = tChart;
Re: WPF TChart program hang
Post by Sandra » Tue Apr 12, 2011 4:05 pm
Hello neurosoft,
Using next code Xaml:
<Window x:Class="WpfApplication1.Window1"
    xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
    xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
    Title="Window1" Height="300" Width="300"
    xmlns:my="clr-namespace:Steema.TeeChart.WPF;assembly=TeeChart.WPF">
    <Grid>
        <my:TChart Margin="0,0,0,0" Name="tChart1" />
    </Grid>
</Window>
And next code:
            tChart1.Axes.Left.AutomaticMaximum = false;
            tChart1.Axes.Left.AutomaticMinimum = false;
            tChart1.Axes.Left.Logarithmic = true;
            tChart1.Axes.Left.Maximum = 100;
            tChart1.Axes.Left.Minimum = 10;
            tChart1.Series.Add(points);
            tChart1.Width = 300;
            tChart1.Height = 63;
It works as expected to us with last version of TeeChartWPF . Please, could you check again if previous code works for you? And also, you can tell us which version of TeeChartWPF are you using?
neurosoft
Post by neurosoft » Wed Apr 13, 2011 1:52 pm
Hello!
I am using version TChart 2010 version 4.0.2011.2083, Visual Studio 2010 SP1
Here is source code (you need only chage ref of TChart to your folder)
TChartWpfApplication.zip
source code
(9.43 KiB) Downloaded 657 times
Post by Sandra » Thu Apr 14, 2011 10:48 am
Hello neurosoft,
I could reproduce your problem using last version 4.0.2011.2083 of TeeChartWPF but not with source code, so it will be solved in next version of TeeChart.Net. I recommend you to be aware at this forum, our RSS news feed, Steema Software's twitter or facebook accounts for new release announcements and what's implemented on them.
neurosoft
Post by neurosoft » Wed Apr 20, 2011 10:28 am
Hello!
I have loaded latest TChart version 4.1.2011.4193 from 19.04.2011, but this problem remained. Please check it!
Post by Sandra » Wed Apr 20, 2011 1:40 pm
Hello neurosoft,
You are right. I have added your request in bug list with number [TW16015529]. We will try to fix it in next versions of TeeChart.Net.
