Open of Form with TreeMap - causes CPU Usage to climb..
TimeAcct
Post by TimeAcct » Sat Feb 26, 2011 11:54 pm
I have an interesting problem. I have a TreeMap graph setup on a form. When I try to open that form - it causes the CPU usage to climb to 13% on my Quadcore CPU - and Delphi basically hangs.
I am not convinced it is a TeeChart issue - as I have some other funny things happening with Delphi - but thought I would check to see if you have seen this happen elsewhere??
Bradley
Re: Open of Form with TreeMap - causes CPU Usage to climb..
Post by Yeray » Mon Feb 28, 2011 11:55 am
Hi Bradley,
Can you please tell us what IDE and TeeChart version are you using?
Could you also please tell us the exact steps we should follow to reproduce the problem here from a new simple application?
TimeAcct
Post by TimeAcct » Mon Feb 28, 2011 4:41 pm
I have not been able to reproduce it at this time - except in our large project. That is partly the reason for the question :)
As to which version - I am using Delphi XE Enterprise - and the first TeeChart Version to work with Dephi XE.
Bradley
Post by Yeray » Tue Mar 01, 2011 2:59 pm
Hi Bradley,
I'm trying to reproduce the problem in a new simple application (RAD Studio XE + TeeChart Pro v2010.02) with only a chart and a button in the form. Here is the code I'm running:
uses TeeWorldSeries;
  with Chart1.AddSeries(TWorldSeries) as TWorldSeries do
    Map:=wmWorld;
    FillSampleValues();
  Chart1.View3D:=false;
  Chart1.Legend.Visible:=false;
Looking the Task Manager when clicking the button, I see the application taking the 8% of the CPU for about a second and then the application continues using 0% CPU if I don't interact with the chart.
I've tested it in an AMD 3800+ with 3.5GB RAM.
Maybe your application is doing something, repainting the chart continuously?
It will be helpful if you can arrange a simple example project we can run as-is to reproduce the problem here.
