GetAxisLabel Event
rossmc
GetAxisLabel Event
Post by rossmc » Fri Feb 25, 2011 7:37 am
I'm trying to use the GetAxisLabel event to do some basic modification of my labels. However, I have multiple series plotted on the chart. One on right axis, one on left axis, and then some additional custom axis.
The question is, in the GetAxisLabel event, is there a way to tell which axis raised the event? So in the code for the event I can check which axis is currently having it's labels drawn?
Re: GetAxisLabel Event
Post by Yeray » Fri Feb 25, 2011 10:28 am
Hi rossmc,
You could check the "sender" parameter:
        void tChart1_GetAxisLabel(object sender, Steema.TeeChart.GetAxisLabelEventArgs e)
            if (sender == tChart1.Axes.Left)
                // do something
            else if (sender == tChart1.Axes.Right)
                //do something else
