Border around bars in Bar chart is always visible in GDI+ mode. To repro:
1) create bar chart
2) start Tee Editor and turn off border visibility for bars. Borders disappear.
3) turn on GDI+ mode. Borders are back. I can change border style, color and I see changes while "Visibility" check-box is unchecked.
Actually, there are more borders appear around the graph in GDI+ mode. Bars in Bar chart is the simplest case.
Alex.
GDI+ : a border around bars in Bar chart is always visible.
Re: GDI+ : a border around bars in Bar chart is always visible.
Hi Alex,
In v8.07, in GDI+ you could hide the BarPen as follows:
However, in v2010, the following code doesn't hide the BarPen.
A workaround is to make the BarPen.Style to bsClear, but it's not exactly the same:
So I've added it to the defect list to be revised for future releases (TV52015417).
uses Series, TeeGDIPlus;
FillSampleValues();
BarPen.Visible:=false;
Chart1.Canvas:=TGDIPlusCanvas.Create;
FillSampleValues();
//BarPen.Style:=psClear; //workaround not perfect
with TTeeGDIPlus.Create(self) do
TeePanel:=Chart1;
Active:=true;
