Back Image Gif
mivchart
Back Image Gif
Post by mivchart » Tue Dec 28, 2010 10:22 am
I would like to display a GIF image in background with animation in the TeeTree is this possible?
how to make the code in runtime?
Re: Back Image Gif
Post by Yeray » Wed Dec 29, 2010 2:02 pm
Hi mivchart,
The following code seems to work fine for me here:
uses TeeGif;
  Tree1.BackImage.LoadFromFile('C:\tmp\Triple-Spiral-Labyrinth-animated.gif');
Doesn't it for you?
mivchart
Re: Back Image Gif
Post by mivchart » Thu Dec 30, 2010 7:00 am
Ok,
But Backimage with animation Gif ?
Re: Back Image Gif
Post by Yeray » Thu Dec 30, 2010 8:32 am
Hi mivchart,
Here it is the gif I used to check it:
I can see the animation in the tree.
mivchart
Re: Back Image Gif
Post by mivchart » Fri Dec 31, 2010 3:22 pm
Ok, that good,
but for your information, don't load in desgin mode Teetree > crash IDE D2007.
If you load image by coe in runtime > this Ok
thanks
Re: Back Image Gif
Post by Yeray » Mon Jan 03, 2011 10:54 am
Hi mivchart,
I've been able to run it in D2007 here without any error. I've tried it in design time and also at runtime. Here is the code I used:
uses TeeGif;
However I've seen that the animation is lost and the image is static. I've added it to the wish list to be revised for future releases (TV52015342).
