TeeChart and IntraWeb
johnnix
Post by johnnix » Tue Dec 14, 2010 7:13 am
I am very sorry if this is out of topic. I have an application that about 80% is all about charts and I need to investigate the possibility to use IntraWeb to make a standalone version of it. Can TeeChart be used with IntraWeb? Is there any special version for that? Any examples? :)
Kindest regards
Re: TeeChart and IntraWeb
Post by Yeray » Tue Dec 14, 2010 4:20 pm
Hi jonnix,
Here you have the TeeChart for Intraweb packages for the environment:
TeeChart VCL v2010
Intraweb XI
Delphi 2010
IW110TeeChartPro9_140.zip
(6.66 KiB) Downloaded 741 times
If that's not your exact environment, you'll have to adapt them to your environment, something similar to what's explained in the QuickReport article here. You may be interested on reading the article too if you don't know how to compile and install the package.
And a demo example can be found in the Teecahrt installation folder, under Examples/VCL for the Web
johnnix
Post by johnnix » Wed Dec 15, 2010 7:09 am
Thank you for the information. I will give it a try :)
