Display graph without weekends
Petar
Post by Petar » Mon Nov 29, 2010 4:10 pm
I have a problem with bar charts. I have values only on working days and wish to plot only that data (without weekends).
Hereafter is a sample of my code:
With AxTChart
	.AddSeries(TeeChart.ESeriesClass.scBar)
	.Series(IntSerie).asBar.BarStyle = TeeChart.EBarStyle.bsRectGradient
	.Series(IntSerie).XValues.DateTime = TRUE
	.Series(IntSerie).asBar.BarWidthPercent = 100
End With
For i = 0 To oData.Count - 1
       eElement = oData.Item(i)
	AxTChart.Series(IntSerie).AddXY(DateValue(eElement.Date).ToOADate(), eElement.Value, "", AxTChart.Series(IntSerie).Color)
Next i
If I 'm using above code I will have Friday Bar larger 3 times the others bars, because it includes Saturday and Sunday, even though they are null values.
If I force Sunday and Saturday values to be 0 or Nothing , Friday Bar will be OK, but there will be a gap between Friday and Monday.
I was inspired by a solution in the forum to change Series(IntSerie).XValues.DateTime to FAlse and add points AS 1,2,3 ....
with dates as corresponding lables, but this will cause problems in my tool to detect missing data and compare 2 separate graphs.
It's critical for me to have XValues.DateTime = True.
Do you have any solution?
Thank you
Petar
Re: Display graph without weekends
Post by Petar » Mon Nov 29, 2010 4:26 pm
Examples
Data without weekends(null). Friday bar too large
Data with weekends values forced to 0
Post by Sandra » Tue Nov 30, 2010 2:58 pm
Hello User1,
You can do something as next code for get a chart without weekends:
    Private NotDateTime As Boolean
    Private value As Integer
    Private tmp As Integer
Private Sub Check1_Click()
If Check1.value = 1 Then
    AddAsNoWeekend
  Else
    AddAsDatetime
  End If
Private Sub Form_Load()
      TChart1.Aspect.View3D = False
      AddAsDatetime
Private Sub AddAsDatetime()
Dim tmpopen, tmp As Integer
  ' This option simulates a sequential datetime Axis
  ' Candle Series
  NotDateTime = False
  TChart1.RemoveAllSeries
  TChart1.AddSeries scBar
  TChart1.Axis.Bottom.Labels.Angle = 90
    With TChart1
            .Series(0).asBar.BarStyle = TeeChart.EBarStyle.bsRectGradient
            .Series(0).XValues.DateTime = True
            .Series(0).asBar.BarWidthPercent = 50
            .Series(0).Marks.Visible = False
    End With
  With TChart1.Series(0)
    .Clear
    tmpopen = 1000 + Rnd(100)
    For t = 0 To 14
      tmp = Int(100 * Rnd - 50)
      .AddXY Format(Now - 15, "000000") + t, tmpopen, "", vbRed
      tmpopen = tmpopen + tmp
    Next t
  End With
Private Sub AddAsNoWeekend()
  'Create an array of example dates
Dim myDates(14) As Variant
Dim StartDate As Date
  ' If this were to have a database datasource it would be simpler
  ' as you could use Series(xx).LabelsSource
  ' If using ADO Recordset the following principle would apply, replacing the
  ' Array with a step-through the Recordset
  NotDateTime = True
  StartDate = Now - 15
  For i = 0 To 13
    While (Weekday(StartDate) = 1) Or (Weekday(StartDate) = 7)
      StartDate = StartDate + 1
    Wend
    myDates(i) = Format(StartDate, "d-mmm-yyyy")
  Next i
    With TChart1
        End With
    .XValues.DateTime = False
    .Clear
    For t = 0 To 8
      .AddXY 1 + t, tmpopen, "", vbRed
      .PointLabel(t) = myDates(t)
    Next t
  End With
Could you tell us if previous code works as you want?
Petar
Post by Petar » Tue Nov 30, 2010 3:35 pm
Hi Sandra,
as I mentioned in my 1st post:
"...I was inspired by a solution in the forum to change Series(IntSerie).XValues.DateTime to FAlse and add points AS 1,2,3 ....
with dates as corresponding labels, but this will cause problems in my tool.."
and so I cannot use your solution:
I'll explain you why:
1) Example: Chart historic daily values of traded Volume from 01/01/09 to 31/12/09 . If I have missing daily data for a period of 1 month (ex Apr09) and I plot data with your solution, i will not detect easily the missing data because 31/03/09 and 01/05/09 will be next each other and there will be no gap between them. So everything will appear to be correct.
2) It will still be difficult to compute spread between 2 graphs plotted with your code if 1st graph have daily values and 2nd only (Monday and Friday values)
That's why I'm interested to have .XValues.DateTime = True , and I'm looking for an option to not show Weekends on DateTime type axis.
User1
Post by Sandra » Wed Dec 01, 2010 12:06 pm
Hello User1,
The solution above allows change format of DateTime for example dd/mm/yyyy as do in line below:
myDates(i) = Format(StartDate, "dd/mm/yyyy")
Moreover, if you want a month without dates you can add nulls in its points. For example if you want April without dates, you can add nulls the points correspond April.
Petar
Post by Petar » Wed Dec 01, 2010 3:46 pm
It's not working for me:
I cannot understand what I'm missing. I add Null values on weekends,
but I still see week-end dates and gap between friday and monday. Hereafter a sample code:
With AxTChart
	.Series(0).asBar.Gradient.Visible = True
	.Series(0).asBar.BarWidthPercent = 60
end with
AxTChart.Series(0).AddXY(Math.Round(DateValue("26/11/10").ToOADate(), 0), 120, "", AxTChart.Series(0).Color)
AxTChart.Series(0).AddNullXY(Math.Round(DateValue("27/11/10").ToOADate(), 0), 0, "")
AxTChart.Series(0).AddNullXY(Math.Round(DateValue("28/11/10").ToOADate(), 0), 0, "")
AxTChart.Series(0).AddXY(Math.Round(DateValue("29/11/10").ToOADate(), 0), 150, "", AxTChart.Series(0).Color)
Any idea? Can you give me an example?
Post by Yeray » Thu Dec 02, 2010 9:11 am
Hi User1,
Adding values with AddXY method gives you the opportunity to control where exactly in the axis will be drawn each bar. And I think that's what you need.
If you set the bottom axis to be DateTime, you still have to control the separation between one bar and the next one as DateTimes are in fact doubles. It's the expected behaviour to see more separation between two bars with a weekend increment in XValue than between two consecutive days bars.
Adding the date as XValue (or adding Null values), doesn't allow you to control this separation. That's why I recommend you to use a variable to control the XValue and increment its value in one unit from Friday to Monday, the same as from Monday to Tuesday.
And when you want to add a gap between bars (for example to showing that there is no data in a month) you simply have to increment the XValue in more units.
  TeeCommander1.ChartLink = TChart1.ChartLink
  TeeCommander2.ChartLink = TChart2.ChartLink
  TChart2.Aspect.View3D = False
  TChart2.Legend.Visible = False
  TChart2.AddSeries scBar
  Dim XValue, YValue As Double
  Dim i As Integer
  Dim myDate As Date
  XValue = 0
  myDate = DateValue("01/01/2010")
  For i = 0 To 89
    If Weekday(myDate) <> vbSaturday And Weekday(myDate) <> vbSunday Then
      YValue = Rnd * 100
      If Month(myDate) <> 2 Then
        TChart1.Series(0).AddXY XValue, YValue, Str$(myDate), clTeeColor
      End If
      TChart2.Series(0).AddXY XValue, YValue, Str$(myDate), clTeeColor
      XValue = XValue + 1
    End If
    myDate = myDate + 1
  Next i
  TChart2.Environment.InternalRepaint
  TChart1.Series(0).asBar.BarWidth = TChart2.Series(0).asBar.BarWidth
So adding the following to the code above doesn't affect the result:
  TChart1.Series(0).XValues.DateTime = True
  TChart2.Series(0).XValues.DateTime = True
If you need a more precise example, please try to arrange a simple example project we can run as-is to reproduce the behaviour here, showing us something similar to the two charts you are trying to obtain and the tool you are using.
Petar
Post by Petar » Fri Dec 03, 2010 3:08 pm
Thank you,
however it's still not what we were looking for. I think that new version of TeeChart has a new display tool : Vertical Break Lines and you can specify the number of points you want to hide after specific point (in this case Friday).
But I think for the moment we will change our tool and control the X axis AddPointXY ( with 0,1,2....) as you bough suggested.
User1
