As part of of a data analysis I need to plot between 1 and 5 points on a polar plot with mark tip values. However if 1 or 2 points are plotted the mark tip values are not displayed when the mouse is placed over the points. For 3 or more points the mark tip values is displayed. I have a work arround for the problem, but any suggestions as to where I am going wrong would be welcome. I have attached some sample code that illustrates the problem.
Many thanks
Paul
Polar Bar Mark Tips
Polar Bar Mark Tips
- PolarPlotTest.zip
- Polar bar mark tip example
- (14.56 KiB) Downloaded 274 times
Re: Polar Bar Mark Tips
Hello Paul,
I couldn't reproduce your problem using last version of TeeChart.Net. Could you please, tell what version of TeeChart.Net are you using?
Soory I should have said I am using TeeChart.NET Verison 2009 .NET 2.0 build 4.0.2009.35590. Due to my clients requirments I need to use .NET 2.0 versions.
Paul
Paul
Hi Paul,
MarkTips work fine in both charts for me here using latest TeeChart for .NET 2010 release works fine for me here. Can you please check if it solves the problem at your end?
Narcis
I have just downloaded the .NET 2010 evaluation version and that resolves the problem with the polar bar mark tips.
Many thanks
Paul
Many thanks
Paul
Hi Paul,
According to our records you are entitled to download upgrades for your license until 14th October 2010 so you can use your license number to download latest TeeChart for .NET 2010 release.
