Surface 3D Chart does not display
Jack
Post by Jack » Tue Sep 28, 2010 2:07 am
I am unable to get a Surface 3D chart to display when I add X, Y, and Z values to the surface using 3 ArrayLists of Doubles.
The axes are visisble, the legend is visible, everything is visible except the actual data surface. If I simply change ss.add(xV, yV, zV), where xV, yV, and zV are populated ArrayLists, to ss.fillSampleValues(100) the surface is visible. I have called setIrregularGrid(true).
While the values in each ArrayList have a wide dynamic range, the axis labels are reasonable and thus I would expect the surface to appear. What am I missing?
Jack Copper
Re: Surface 3D Chart does not display
Post by Narcís » Wed Sep 29, 2010 10:20 am
Hi Jack,
Probably your data doesn't accomplish with surface series requirements. Such series work as I explained here. If you think your data fits in this structure please post a simple code snippet we can run "as-is" to reproduce the problem here.
