Last version of TQRChart for C++ builder 2010
Marco
Post by Marco » Tue Sep 14, 2010 10:55 am
I updated my teechart package to V8.07, and my quick report package to V5.042. I used C++ builder 2010.
Is there a TQRChart package compatible with these versions ?
Where can I find it ?
Mo
Re: Last version of TQRChart for C++ builder 2010
Post by Yeray » Wed Sep 15, 2010 1:49 pm
Hi Mo,
In the QuickReport article here, there are detailed instructions on how to prepare the TQRChart packages for your own environment.
However, we prepared the packages for an environment similar to yours some time ago. Find the sources and the compiled attached.
You can try using directly the compiled as explained in the instructions above or recompile the sources.
If you find any problem with the process, don't hesitate to let us know.
compiled Tee8QR5D14.zip
(45.7 KiB) Downloaded 1888 times
sources Tee8QR5D14.zip
(7.13 KiB) Downloaded 1704 times
Marco
Post by Marco » Wed Sep 15, 2010 2:25 pm
Thanks for your answer, i'll try following your instructions.
Mo
RichTat
Post by RichTat » Mon Nov 15, 2010 3:59 pm
I have just downloaded the latest TeeChart release v2010.01.11004 (which has cured repaint bugs - thank you) and purchased the latest QuickReport V505 for Delphi and v504C for C++ Builder. I followed exactly the instructions given in the article you specified for how to prepare TQRChart component using the packages installed with TeeChart and everything works for Delphi 2010.
With C++ Builder 2010 I have reached the point where I can compile and run a project with a form containing a QuickReport component and a TChart component. However I have no C++ Builder 2010 design or run-time package for TQRChart so I have no TQRChart component to install into the design-time palette, unlike Delphi where you supplied these.
Would it be possible for you to supply the relevant files for a C++ Builder 2010 TQRChart component please ?
regards - Richard
Post by Yeray » Tue Nov 16, 2010 1:52 pm
Hi Richard,
Here you have the packages for TeeChart Pro v8 with QuickReport v5 in C++ Builder 2010.
I hope it helps.
Tee8QR5C14.zip
(17.36 KiB) Downloaded 1490 times
RichTat
Post by RichTat » Wed Nov 17, 2010 2:12 pm
I have spent a day on this and given up.
The Tee Chart version 8 is different from mine, the references to CodeGear and RAD Studio 5.0 are incorrect., the personality numbers are different, the file names are different.
The TQrTeeReg.pas files in my Delphi and C++ versions are different.
I have tried renaming files and changing references in the project files but the design project will not load with an error referring to the personality 14 line.
The run-time library project refers to Personality 12 and loads and now compiles but changing 14 to 12 in the design package produces a different error.
I am not sure what I am doing - the reason I buy VCL tool packages like TeeChart and QuickReport is that all this type of IDE programming is done for me.
Perhaps the author David Bernada could be persuaded to produce an up-to-date version for TeeChart 2010 and QuickReport 5.
Please advise me what to try next.
Richard
Post by Yeray » Wed Nov 17, 2010 5:25 pm
Hi Richard,
I meant you had to follow the instructions in the QuickReport article to rename, edit and recompile the packages I posted yesterday. Note that they are the packages for TeeChart Pro v8 with QuickReport v5 in C++ Builder 2010, while you want the packages for TeeChart Pro v2010 with QuickReport v5 in C++ Builder 2010, if I'm not wrong.
Please, confirm it and I'll try to prepare them for you.
RichTat
Post by RichTat » Wed Nov 17, 2010 6:48 pm
Yes, I have C++ Builder 2010, TeeChart Pro 2010 for Delphi 2010 and C++ Builder 2010, QulckReport 5.05 for Delphi 2010 and a separate QuickReport 5.04 for C++ Builder 2010. TQRChart component for Delphi 2010 is installed.
I need TQRChart component foor C++Builder 2010 and QuickReport V5.04.
I expected to find .bpk files in the download but did not.
I look forward to hearing from you.
Richard
Post by Yeray » Mon Nov 22, 2010 1:46 pm
Hi Richard,
Excuse us for the delay. We haven't forgotten you. We'll be back to you asap.
Post by Yeray » Wed Nov 24, 2010 12:27 pm
Hi Richard,
Here there are the packages (both sources and compiled) that work for me here.
Try to recompile the sources (pay attention to the include, library and output paths) or use the compiled files included.
Put the runtime package (Tee9QR5C14.bpl) to Windows\System32 folder, the design time package to the IDE bin folder (Embarcadero\RAD Studio\7.0\bin), the .obj files to "Embarcadero\RAD Studio\7.0\lib\obj" and the rest to "Embarcadero\RAD Studio\7.0\lib"
Tee9QR5C14.zip
(1.24 MiB) Downloaded 1672 times
RichTat
Post by RichTat » Thu Nov 25, 2010 5:36 pm
I have downloaded your file and tried to compile the projects but there are file path references in the project file which are not configurable in the IDE PROJECT OPTIONS as far as I can see but which have to be changed. I may try to go through the files in detail at a later date.
However, using your compiled files to install the component enables me to compile and run a simple test project so I will see how I get on with my live projects.
Thank you for your efforts.
Richard
Post by Yeray » Fri Nov 26, 2010 8:26 am
Hi Richard,
RichTat wrote:I have downloaded your file and tried to compile the projects but there are file path references in the project file which are not configurable in the IDE PROJECT OPTIONS as far as I can see but which have to be changed. I may try to go through the files in detail at a later date.
You can try editing the package files manually with notepad or similar. That's how I do it.
RichTat wrote:However, using your compiled files to install the component enables me to compile and run a simple test project so I will see how I get on with my live projects.
If the files are correctly placed and referenced, the package compiled here should work on the same environment anywhere.
Marco
Post by Marco » Tue Mar 08, 2011 10:09 am
I still need to install TQRChart component on my C++ builder 2010 with TeeChart 8.06 and QR5. I well followed the TQR installation article on your website before opening the compiled package Tee8QR5C14.zip.
I think the problem is I can't open the file "TQR_Tee8QR5C14.groupproj" because there is an error on DclTee8QR5C14.cbproj file. Here is the error message :
Fatal error 250477278. Line 88, column 58.
I can open separatly the "Tee8QR5C14.cbproj", I can build and install it but it isn't enough to install correctly TQRChart.
Do you have an idea for my problem ?
Mo
Post by Yeray » Wed Mar 09, 2011 10:57 am
I've taken the packages posted above and I've edited them to use TeeChart v8 instead of TeeChart v2010.
I've recompiled them and checked that they work fine for me with TeeChart Pro VCL v8.08 and RAD Studio 2010.
Tee8QR5C14.zip
(1.5 MiB) Downloaded 1537 times
Marco
Post by Marco » Wed Mar 09, 2011 4:41 pm
With this one installation succeeded, thanks a lot !
Mo
