.net Application not able to read License info. in Test Env.
Nitin
Post by Nitin » Thu Aug 19, 2010 10:03 am
We have two different application one is integrated and other is standalone and both of them are used to launch our another application which is using TeeChart version 4.0.2009.35592.
Problem is when I am trying to launch the application from the Integrated Mode application it is able to find the TeeChart License information. Whereas if I am doing it from the Standalone application it is giving below exception.
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. ---> System.ComponentModel.LicenseException: An instance of type 'Steema.TeeChart.Chart' was being created, and a valid license could not be granted for the type 'Steema.TeeChart.Chart'. Please, contact the manufacturer of the component for more information.
at System.ComponentModel.LicenseManager.Validate(Type type, Object instance)
at Steema.TeeChart.Chart..ctor()
at Steema.TeeChart.TChart..ctor()
at Honeywell.QualityOptiMISER.Presentation.ProfileControl.InitializeComponent()
at Honeywell.QualityOptiMISER.Presentation.ProfileControl..ctor()
at Honeywell.QualityOptiMISER.Presentation.ContourMapControl.InitializeComponent()
at Honeywell.QualityOptiMISER.Presentation.ContourMapControl..ctor()
at Honeywell.QualityOptiMISER.Presentation.ContourMap.InitializeComponent()
at Honeywell.QualityOptiMISER.Presentation.ContourMap..ctor()
--- End of inner exception stack trace ---
at System.RuntimeTypeHandle.CreateInstance(RuntimeType type, Boolean publicOnly, Boolean noCheck, Boolean& canBeCached, RuntimeMethodHandle& ctor, Boolean& bNeedSecurityCheck)
at System.RuntimeType.CreateInstanceSlow(Boolean publicOnly, Boolean fillCache)
at System.RuntimeType.CreateInstanceImpl(Boolean publicOnly, Boolean skipVisibilityChecks, Boolean fillCache)
at System.Activator.CreateInstance(Type type, Boolean nonPublic)
at System.RuntimeType.CreateInstanceImpl(BindingFlags bindingAttr, Binder binder, Object[] args, CultureInfo culture, Object[] activationAttributes)
at System.Activator.CreateInstance(Type type, BindingFlags bindingAttr, Binder binder, Object[] args, CultureInfo culture, Object[] activationAttributes)
at System.Reflection.Assembly.CreateInstance(String typeName, Boolean ignoreCase, BindingFlags bindingAttr, Binder binder, Object[] args, CultureInfo culture, Object[] activationAttributes)
at System.Reflection.Assembly.CreateInstance(String typeName, Boolean ignoreCase)
at Honeywell.HISOFT.DownloadManager.AssemblyLoader.DownloadUserControl(Hashtable keys)
at Honeywell.HISOFT.Desktop.HISOFTReferences.ShowChildWindow(String HISOFTServer, Control parent, Hashtable keys, Color color, String fontFamily, Single fontSize)
at Honeywell.HISOFT.Desktop.HISOFTTreeMenu.DoOpen(TreeNode treenode)
at Honeywell.HISOFT.Desktop.HISOFTTreeMenu.treeView1_DoubleClick(Object sender, EventArgs e)
at System.Windows.Forms.Control.OnDoubleClick(EventArgs e)
at System.Windows.Forms.TreeView.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000)
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
HISOFTTreeMenu
Assembly Version: 1.0.3736.24956
Win32 Version: 1.0.3736.24956
CodeBase: file:///E:/Program%20Files%20(x86)/Honeywell/HISOFT%20Menu/HISOFTTreeMenu.dll
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
Accessibility
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
System.Xml
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
Microsoft.mshtml
Assembly Version: 7.0.3300.0
Win32 Version: 7.0.3300.0
CodeBase: file:///C:/Windows/assembly/GAC/Microsoft.mshtml/7.0.3300.0__b03f5f7f11d50a3a/Microsoft.mshtml.dll
DownloadManager
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///E:/Program%20Files%20(x86)/Honeywell/HISOFT%20Menu/DownloadManager.DLL
HISOFTDateTime
Win32 Version: 6.6.6.0
CodeBase: file:///E:/Program%20Files%20(x86)/Honeywell/HISOFT%20Menu/HISOFTDateTime.DLL
System.Configuration
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
Strings
Assembly Version: 0.0.0.0
Win32 Version: 0.0.0.0
CodeBase: file:///E:/Program%20Files%20(x86)/Honeywell/Honeywell%20HISOFT%20SDK/pdk/Resources/Strings.dll
Honeywell.HISOFT.BusinessCore.BusinessCore
Assembly Version: 10.3.25.0
Win32 Version: 10.3.25.0
CodeBase: file:///C:/Users/Administrator/AppData/Local/Honeywell/HISOFT/Cache/localhost/BusinessCore_100325_135422_Honeywell.HISOFT.BusinessCore.BusinessCore.dll
log4net
Assembly Version: 1.2.10.0
Win32 Version: 1.2.10.0
CodeBase: file:///C:/Windows/assembly/GAC/log4net/1.2.10.0__1b44e1d426115821/log4net.dll
nunit.framework
Assembly Version: 2.1.4.0
Win32 Version: 2.1.4.0
CodeBase: file:///C:/Users/Administrator/AppData/Local/Honeywell/HISOFT/Cache/localhost/BusinessCore_030911_215530_nunit.framework.dll
System.Runtime.Remoting
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Runtime.Remoting/2.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
Strings.resources
CodeBase: file:///E:/Program%20Files%20(x86)/Honeywell/Honeywell%20HISOFT%20SDK/pdk/Resources/en/Strings.resources.DLL
Honeywell.QualityOptiMISER.Presentation.QualSpecManager
Assembly Version: 9.1.31.0
Win32 Version: 9.1.31.0
CodeBase: file:///C:/Users/Administrator/AppData/Local/Honeywell/HISOFT/Cache/localhost/Presentation_100128_031738_Honeywell.QualityOptiMISER.Presentation.QualSpecManager.dll
Honeywell.QualityOptiMISER.Presentation.QOApplicationBase
Assembly Version: 5.4.22.0
Win32 Version: 5.4.22.0
CodeBase: file:///C:/Users/Administrator/AppData/Local/Honeywell/HISOFT/Cache/localhost/Presentation_100128_032457_Honeywell.QualityOptiMISER.Presentation.QOApplicationBase.dll
Honeywell.QualityOptiMISER.Presentation.CommonModules
Assembly Version: 10.1.31.0
Win32 Version: 10.1.31.0
CodeBase: file:///C:/Users/Administrator/AppData/Local/Honeywell/HISOFT/Cache/localhost/Presentation_100320_040404_Honeywell.QualityOptiMISER.Presentation.CommonModules.dll
Honeywell.QualityOptiMISER.BusinessObjects.CommonDef
CodeBase: file:///C:/Users/Administrator/AppData/Local/Honeywell/HISOFT/Cache/localhost/Presentation_100202_010714_Honeywell.QualityOptiMISER.BusinessObjects.CommonDef.dll
CrystalDecisions.CrystalReports.Engine
Assembly Version: 10.5.3700.0
Win32 Version: 10.5.0.1943
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/CrystalDecisions.CrystalReports.Engine/10.5.3700.0__692fbea5521e1304/CrystalDecisions.CrystalReports.Engine.dll
CrystalDecisions.ReportSource
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/CrystalDecisions.ReportSource/10.5.3700.0__692fbea5521e1304/CrystalDecisions.ReportSource.dll
CrystalDecisions.Shared
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/CrystalDecisions.Shared/10.5.3700.0__692fbea5521e1304/CrystalDecisions.Shared.dll
FarPoint.Win.Spread
Assembly Version: 4.0.3512.2008
Win32 Version: 4.0.3512.2008
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/FarPoint.Win.Spread/4.0.3512.2008__327c3516b1b18457/FarPoint.Win.Spread.dll
System.Data
CodeBase: file:///C:/Windows/assembly/GAC_32/System.Data/2.0.0.0__b77a5c561934e089/System.Data.dll
Honeywell.QualityOptiMISER.Presentation.QualityDiary
Assembly Version: 10.4.9.0
Win32 Version: 10.4.9.0
CodeBase: file:///C:/Users/Administrator/AppData/Local/Honeywell/HISOFT/Cache/localhost/Presentation_100326_223537_Honeywell.QualityOptiMISER.Presentation.QualityDiary.dll
TeeChart
Assembly Version: 4.0.2009.35592
Win32 Version: 4.0.2009.35592
CodeBase: file:///C:/Users/Administrator/AppData/Local/Honeywell/HISOFT/Cache/localhost/Presentation_090925_014300_TeeChart.dll
FarPoint.Win
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/FarPoint.Win/4.0.3512.2008__327c3516b1b18457/FarPoint.Win.dll
CodeBase: file:///C:/Users/Administrator/AppData/Local/Honeywell/HISOFT/Cache/localhost/Presentation_100322_210828_Honeywell.QualityOptiMISER.Presentation.Profile.dll
Honeywell.QualityOptiMISER.Presentation.QualityCheckControl
Assembly Version: 7.11.12.0
Win32 Version: 7.11.12.0
CodeBase: file:///C:/Users/Administrator/AppData/Local/Honeywell/HISOFT/Cache/localhost/Presentation_100128_032326_Honeywell.QualityOptiMISER.Presentation.QualityCheckControl.dll
Honeywell.QualityOptiMISER.Presentation.Trend
CodeBase: file:///C:/Users/Administrator/AppData/Local/Honeywell/HISOFT/Cache/localhost/Presentation_100128_031426_Honeywell.QualityOptiMISER.Presentation.Trend.dll
FarPoint.Excel
Assembly Version: 4.0.3518.2008
Win32 Version: 4.0.3518.2008
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/FarPoint.Excel/4.0.3518.2008__327c3516b1b18457/FarPoint.Excel.dll
CodeBase: file:///C:/Users/Administrator/AppData/Local/Honeywell/HISOFT/Cache/localhost/Presentation_100406_174019_Honeywell.QualityOptiMISER.Presentation.ContourMap.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
.Net Application not able to read License info. in Test Env.
Could you please let me know from where generally license information stored, or is there any way to troubleshoot the issue.
Nitin
Re: .net Application not able to read License info. in Test Env.
Post by Marc » Thu Aug 19, 2010 2:05 pm
Hello Nitin,
By standalone, that means it is calling the TeeChart application via assembly load? ... and integrated calls the TeeChart application as a project, part of a common solution?
I would not expect a problem in either case if the resulting assembly is not itself being used in a design context. I see you are using TeeChart build 4.0.2009.35592 dated Sept. 2009. TeeChart internal assembly license checks were relaxed for the next update (build Build 4.0.2009.42283, Dec 2009) so Before we investigate further I recommend that you move to the latest available TeeChart build.
Nitin
Post by Nitin » Mon Aug 23, 2010 7:07 am
Marc,
Thanks for your help.
I tried with the following version of TeeChart 4.0.2009.62332 and now issue is not there.
Thanks again,
Nitin
