Candle HighLowPen coloring.
Snarkle
Post by Snarkle » Mon Aug 09, 2010 7:36 am
Greetings,
Is there a way to make a Candle Stick HighLowPen.Color the same as the Stick color.
example ...
Desired Candle look
You can see that the HigLowPen's color is the same as the rest of the candle.
I looked at this example "Welcome !\Chart styles\Financial\Candle (OHLC)\Candle HighLow pen" but it only covers changing ALL the HigLowPen's to one color.
Failing that .. I guess I'll have to color each HigLowPen individually .. any suggestions on where is the best place to do this ... or do I need to do a separate iteration through the Candle series once its drawn ...
Cheers Phil.
Cheers Phil.
Re: Candle HighLowPen coloring.
Post by Yeray » Tue Aug 10, 2010 2:48 pm
Hi Phil,
You could use GetPointerStyle event to change the series Pen.Color before drawing each point:
            Steema.TeeChart.Styles.Candle Candle1 = new Steema.TeeChart.Styles.Candle(tChart1.Chart);
            Candle1.FillSampleValues(10);
            Candle1.CandleWidth = 15;
            Candle1.UpCloseColor = Color.Green;
            Candle1.GetPointerStyle += new Steema.TeeChart.Styles.CustomPoint.GetPointerStyleEventHandler(series1_GetPointerStyle);
        void series1_GetPointerStyle(Steema.TeeChart.Styles.CustomPoint series, Steema.TeeChart.Styles.GetPointerStyleEventArgs e)
            series.Pointer.Pen.Color = e.Color;
Snarkle
Post by Snarkle » Fri Aug 13, 2010 12:40 am
Thanks Yeray that does the trick.
Cheers Phil.
Snarkle
Post by Snarkle » Fri Aug 13, 2010 5:53 am
Greetings .. back again ... did you miss me? no ?? oh well :-)
On the topic of Coloring candles ... with your kind support I have them looking pretty much as I want them ..
And happily whatever color the candle is, so is the PointerStyle color ... perfect ...
However ... the candle coloring happens thanks to the
                    myCandle.Style = CandleStyles.CandleStick;
                    myCandle.UpCloseColor = Color.Green;
                    myCandle.DownCloseColor = Color.Red;
Now when the close price == the open price we like to color our candles grey ... is there a way to color random candles ?
I tried this but just got multicolored Candles ... very pretty .. not so usable ;-)
for (int index = 0; index < dataList.Count; index++)
                double open = Convert.ToDouble(dataList[index].Open);
                double high = Convert.ToDouble(dataList[index].High);
                double low = Convert.ToDouble(dataList[index].Low);
                double close = Convert.ToDouble(dataList[index].Close);
                DateTime idate = dataList[index].Date;
                // Labels for the X axis.
                labels.Add(idate.ToShortDateString());
                /// Color the pointers for the Candles
                Color pointerColor;
                if (open > close) pointerColor = Color.Red;
                else if (close > open) pointerColor = Color.Green;
                else pointerColor = Color.DarkGray;
                myCandle.Colors[index] = pointerColor;
                // Add the data to the Series.
                myCandle.Add(index, open, high, low, close);
Cheers Phil.
Post by Yeray » Fri Aug 13, 2010 3:59 pm
Hi Phil,
If I understood well, you should use again the GetPointer event:
            Candle1.Style = Steema.TeeChart.Styles.CandleStyles.CandleStick;
            Candle1.DownCloseColor = Color.Red;
            //testing values
            Candle1.CloseValues[2] = Candle1.OpenValues[2];
            if (series is Steema.TeeChart.Styles.Candle)
                Steema.TeeChart.Styles.Candle candle = series as Steema.TeeChart.Styles.Candle;
                if (candle.CloseValues[e.ValueIndex] == candle.OpenValues[e.ValueIndex])
                    e.Color = Color.Gray;
Snarkle wrote:Greetings .. back again ... did you miss me? no ?? oh well :-)
:lol:
