SelectionTool blocks
asupriya
Post by asupriya » Tue Jul 20, 2010 3:23 am
7-19-2010 10-10-58 PM.png (2.72 KiB) Viewed 9389 times
As shown in above image, the selection tool puts too many black blocks. Is there a way I can have only at the beginning, middle and at end?
Also, is there a way I can set the transparency of these blocks. Sometimes they are pretty much cover the whole curve that is being selected.
Re: SelectionTool blocks
Post by Yeray » Tue Jul 20, 2010 1:10 pm
Hi asupriya,
asupriya wrote:As shown in above image, the selection tool puts too many black blocks. Is there a way I can have only at the beginning, middle and at end?
I'm afraid it only can be done manually right now. You could use Selected event to calculate the points to draw and draw them using a Points series or drawing them manually at AfterDraw event.
asupriya wrote:Also, is there a way I can set the transparency of these blocks. Sometimes they are pretty much cover the whole curve that is being selected.
Yes, check the Selector tool's property: Brush.Transparency
asupriya
Post by asupriya » Tue Jul 20, 2010 2:05 pm
Yeray wrote:Hi asupriya,
Can you please post a code snippet for this? I am using fastline series. Appreciate your help.
Post by Yeray » Tue Jul 20, 2010 3:32 pm
Hi asupriya ,
Here you have an example to start with:
        private Steema.TeeChart.Tools.Selector select1;
        private Steema.TeeChart.Styles.Line line1;
        private Point[] points;
            line1 = new Steema.TeeChart.Styles.Line(tChart1.Chart);
            line1.FillSampleValues(1000);
            select1 = new Steema.TeeChart.Tools.Selector(tChart1.Chart);
            select1.DrawHandles = false;
            points = new Point[3];
            select1.Selected += new Steema.TeeChart.Tools.SelectorSelectedEventHandler(select1_Selected);
        void select1_Selected(object sender, EventArgs e)
            if (select1.Selection == line1)
                points[0].X = line1.CalcXPos(0);
                points[0].Y = line1.CalcYPos(0);
                points[1].X = line1.CalcXPos(line1.Count / 2);
                points[1].Y = line1.CalcYPos(line1.Count / 2);
                points[2].X = line1.CalcXPos(line1.Count-1);
                points[2].Y = line1.CalcYPos(line1.Count - 1);
                int width = 6;
                Steema.TeeChart.Drawing.Graphics3D gd = tChart1.Graphics3D;
                gd.Brush.Color = Color.Red;
                gd.Brush.Transparency = 50;
                for (int i = 0; i < points.Length; i++)
                    gd.Rectangle(points[i].X - width, points[i].Y - width, points[i].X + width, points[i].Y + width);
asupriya
Post by asupriya » Mon Aug 09, 2010 10:12 pm
Thanks Yeray for the code snippet. Really appreciate it.
Post by Yeray » Tue Aug 10, 2010 8:37 am
Hi asupriya,
You're welcome! :)
