Chart Display with Vertical Bottom Axis Labels of Large Size
Neelam
Post by Neelam » Mon Jul 19, 2010 1:44 pm
When I'm having a chart whose Labels are need to be displayed vertically and labels are very large. Charts in the grid (Y Axis) is not displayed properly. Is it possible to have a scroll bar so that user can see the chart properly.
Labels Issue.zip
Bottm Axis Labels
(6.13 KiB) Downloaded 582 times
Re: Chart Display with Vertical Bottom Axis Labels of Large Size
Post by Sandra » Tue Jul 20, 2010 9:37 am
Hello Neelam,
I suggest two solutions that I think you can use in your application.
First, you can change the size of Margins Left, Right, Bottom or Top, using next line of code:
tChart1.Panel.MarginLeft = 7;
It is an easy solution but it is not very elegant.
Second, I think that it is a best solution for you, because treat size of string label. See next example that demonstrate as string label.
            Steema.TeeChart.Styles.Bar bar1 = new Steema.TeeChart.Styles.Bar(tChart1.Chart);
            Random rnd = new Random();
            bar1.ColorEach = true;
            bar1.Add(4, rnd.Next(100),"TESTESTETETETETEETETETETTESTESTETETETETEETETETET");
            bar1.Add(6, rnd.Next(100),"s");
            bar1.Add(7,rnd.Next(100),"s");
            bar1.Add(9,rnd.Next(100),"s");
            bar1.Marks.Visible = false;
            tChart1.Axes.Left.Labels.Style = Steema.TeeChart.AxisLabelStyle.Mark;
            tChart1.Axes.Bottom.Labels.Style = Steema.TeeChart.AxisLabelStyle.Value;
            bar1.GetSeriesMark +=new Steema.TeeChart.Styles.Series.GetSeriesMarkEventHandler(bar1_GetSeriesMark);
        void bar1_GetSeriesMark(Steema.TeeChart.Styles.Series series, Steema.TeeChart.Styles.GetSeriesMarkEventArgs e)
            if (e.MarkText.Length > 20)
                e.MarkText = e.MarkText.Substring(0, 10) + "...";
