I add a hotspot tool in my web application,but there's some problems occurs. My series is a point series.
1. When I change the points style to Triangle, the hotspot tool doesn't worked well.
2. When I use the hotspot tool in a colorgrid chart ,it also doesn't worked.Is this a bug or is there any property I should set?
The attachment is my application.
Candy
About the using of hotspot tool
- Teechart.rar
- (6.05 KiB) Downloaded 491 times
Re: About the using of hotspot tool
Hello Candy
Thanks for its information. I communicate that it is a bug known to us and it is already added in bug report list with number [TW77013908]. We will try to fix it for next maintenances releases of TeeChart .Net.1. When I change the points style to Triangle, the hotspot tool doesn't worked well.
I could reproduce your problem with last version of TeeChart.Net and I have added it in bug report list with number [TW77015031]. We will try to fix it for next versions of TeeChart.Net.2. When I use the hotspot tool in a colorgrid chart ,it also doesn't worked.Is this a bug or is there any property I should set?
