iEnergy
- Newbie
Post
by iEnergy » Tue Jun 08, 2010 1:19 am
I am using TeeChart for ASP.NET. How do I export and save a chart that would have different style properties.
example
First chart to be generated should have width and height of 200 while second chart will have width and height of 1000 and 800.
guid = Guid.NewGuid().ToString();
fileName = guid + ".png";
largePicFileName = guid + "large" + ".png";
webChart.Chart.Export.Image.PNG.Save(_chartPath + fileName);
_webChart.Width = new Unit(1000);
_webChart.Height = new Unit(800);
webChart.Chart.Export.Image.PNG.Save(_chartPath + largePicFileName);
The above code does not work and renders the size and with similar to the first saved image.
Post
by Yeray » Wed Jun 09, 2010 9:09 am
Hi iEnergy,
I think you are looking for the PNG.Width and PNG.Height properties.
The following seems to work fine here:
tChart1.Export.Image.PNG.Width = 200;
tChart1.Export.Image.PNG.Height = 200;
tChart1.Export.Image.PNG.Save(@"C:\tmp\test_small.png");
tChart1.Export.Image.PNG.Width = 1000;
tChart1.Export.Image.PNG.Height = 800;
tChart1.Export.Image.PNG.Save(@"C:\tmp\test_big.png");
iEnergy
- Newbie
Post
by iEnergy » Thu Jun 10, 2010 4:49 am
Many Thanks Yeray.
