TSeriesPointer Questions
erzsebet
Post by erzsebet » Mon Jun 07, 2010 2:39 pm
I am using TeeeChart v8.06 Pro and Delphi 2010. I'm about to start a new chart project, and I have a few questions about TSeriesPointer. They are:
1. Can the size of the pointer symbol be set per datapoint, or does the size of a TSeriesPointer apply to the whole series?
2. Can custom symbols be used instead of the TSeriesPointerStyle symbols provided?
3. Should the size, pointer style and color be set when adding data points to the series or is there a better way to set those properties?
Thanks!!
-erzsebet
Re: TSeriesPointer Questions
Post by Yeray » Tue Jun 08, 2010 9:25 am
Hi erzsebet,
erzsebet wrote:1. Can the size of the pointer symbol be set per datapoint, or does the size of a TSeriesPointer apply to the whole series?
It applies to the whole series, but you can use OnGetPointerStyle to modify this the pointer properties before each them are drawn. For example:
uses series;
var point1: TPointSeries;
  Chart1.View3D:=false;
  point1:=Chart1.AddSeries(TPointSeries) as TPointSeries;
  point1.FillSampleValues();
  point1.OnGetPointerStyle:=Series1GetPointerStyle;
function TForm1.Series1GetPointerStyle(Sender: TChartSeries; ValueIndex: Integer): TSeriesPointerStyle;
  with Sender as TPointSeries do
    Pointer.Size:=(ValueIndex mod 5) + 3;
    Result:=psRectangle;
erzsebet wrote:2. Can custom symbols be used instead of the TSeriesPointerStyle symbols provided?
A. If you are a source code customer, you can add a TSeriesPointerStyle in TeEngine.pas, for example a psCustom:
  TSeriesPointerStyle=( psRectangle,psCircle,psTriangle,psDownTriangle,
                        psCross,psDiagCross,psStar,psDiamond,psSmallDot,
                        psNothing,psLeftTriangle,psRightTriangle,
                        psHexagon,psVisual, psCustom );
Then, you could modify the method TSeriesPointer.DrawPointer, also in TeEngine.pas and add cour custom drawing there:
Procedure TSeriesPointer.DrawPointer( ACanvas:TCanvas3D; Is3D:Boolean; px,py,tmpHoriz,tmpVert:Integer; ColorValue:TColor; AStyle:TSeriesPointerStyle);
case AStyle of
psCustom: Line(px-5,py,px+5,py);
B. If you are not a source customer, you could set the pointer style to psNothing and draw your pointers directly at
uses series, TeCanvas;
  point1.Pointer.Style:=psNothing;
var px, py: Integer;
    tmpRect: TRect;
  with Chart1.Axes do
    tmpRect:=Rect(Left.PosAxis, Left.IStartPos, Bottom.IEndPos, Bottom.PosAxis);
    px:=CalcXPos(ValueIndex);
    py:=CalcYPos(ValueIndex);
  if PointInRect(tmpRect, px, py) then
    Chart1.Canvas.Line(px-5, py, px+5, py);
erzsebet wrote:3. Should the size, pointer style and color be set when adding data points to the series or is there a better way to set those properties?
The same as 1. The pointer properties are properties from the whole series, but you can change them at OnGetPointerStyle.
Furthermore, note that the color is stored in an array of colors, ValueColor. You can change a point color through it at any moment (and also at OnGetPointerStyle).
erzsebet
Post by erzsebet » Tue Jun 08, 2010 2:48 pm
Yeray, hi!
Thank you very much for answering my questions. I am a source code customer, so thanks for including the source code change options, too! Have a great day!
-erzsebet
Post by Yeray » Tue Jun 08, 2010 3:43 pm
Hi erzsebet,
You're welcome! And have a nice one you too! :D
