Assign different fonts to the Points Labels on Line Graph
CS
Post by CS » Tue Jun 01, 2010 8:50 am
I am Tchart5x user.
I have a requirement in which I need to show the point labels in different fonts.
I am able to set the different colors using .Series(0).PointColor(0) property.
Is there any way to set different fonts for the points ?
Kailas
Re: Assign different fonts to the Points Labels on Line Graph
Post by Yeray » Thu Jun 03, 2010 10:54 am
Hi Kalias,
I'm afraid this is not possible since the font property is a property for the whole series (TChart1.Series(0).Marks.Font) not for each value.
What you could do is to draw your text directly to the canvas like in the following example:
Private Sub Form_Load()
  TChart1.Aspect.View3D = False
  TChart1.AddSeries scPoint
  For i = 0 To 19
    TChart1.Series(0).Add Rnd * 100, "point nº" + Str$(i), clTeeColor
  Next i
  Dim i As Integer
  For i = 0 To TChart1.Series(0).Count - 1
    TChart1.Canvas.Font.Size = (i Mod 10) + 10
    TChart1.Canvas.TextOut TChart1.Series(0).CalcXPos(i), TChart1.Series(0).CalcYPos(i), TChart1.Series(0).PointLabel(i)
  Next i
CS
Post by CS » Tue Oct 26, 2010 8:42 am
I have requirement where I want to draw Rectangle around a text which I am plotting with help from you previously.
Can you help on this ?
Also I need to draw the text in between two point. I have attached attachment for more details.
Values used for this :
CS
Draw Text and Rectangle
Post by Sandra » Tue Oct 26, 2010 1:48 pm
Hello CS,
I have made a simple example for you using rectangle tool. Please check if next code works as you want:
  TChart1.AddSeries scLine
  TeeCommander1.Chart = TChart1
  For i = 0 To 19
  Next i
  Dim i As Integer
  TChart1.Tools.Clear
     With TChart1
        .Tools.Add tcRectangle
        .Tools.Items(i).asRectangle.Shape.CustomPosition = True
        .Tools.Items(i).asRectangle.AutoSize = True
        .Tools.Items(i).asRectangle.Shape.Transparency = 30
        .Tools.Items(i).asRectangle.Left = .Series(0).CalcXPos(i)
        .Tools.Items(i).asRectangle.Top = .Series(0).CalcYPos(i)
        .Tools.Items(i).asRectangle.Text = TChart1.Series(0).PointLabel(i)
    End With
  Next i
Private Sub TChart1_OnScroll()
Private Sub TChart1_OnUndoZoom()
Private Sub TChart1_OnZoom()
CS
Post by CS » Wed Oct 27, 2010 3:00 am
Hi ,
version 5 in which I don't see tcRectangle and TCommander
used "TeeChart5Activex.exe" for installation. We are calling the tchart componets from VB 6.
CS
Post by Narcís » Wed Oct 27, 2010 7:14 am
Hi CS,
TeeCommander is not relevant for the example. You can use Annotation tools instead of Rectangle tools in v5 then. They work pretty much the same way.
