Major BUG in Steema.TeeChart.Axis.AxisDraw.DoDefaultLabels
sb_giag
Post by sb_giag » Thu May 27, 2010 9:49 am
There is a Bug in
resulting in an endless loop.
This happens when a series has values with only a small difference. (eg. 1.0 and 0.99999999999999989 )
see the attachment for an proof.
please fix this as fast as possible.
thanks
stefan
TreeChartBugProof.zip
(39.1 KiB) Downloaded 395 times
Re: Major BUG in Steema.TeeChart.Axis.AxisDraw.DoDefaultLabels
Post by Sandra » Thu May 27, 2010 12:04 pm
Hello sb_giag,
I think that your problem is solved, if you use SetMinMax() property of Axes. Please, see next code and check if it works as you want.
public BugProof()
			line1.Clear();
            DateTime time = DateTime.Now;
            line1.XValues.DateTime = true;
			line1.Add(time, 1.0);
			time = time.AddMinutes(15);
			line1.Add(time, 0.99999999999999989);
            panel1.Axes.Left.Automatic = false;
            panel1.Axes.Left.SetMinMax(0.5,1.5);
            panel1.Axes.Left.Increment = 0.01;
            panel1.Axes.Bottom.Increment = Steema.TeeChart.Utils.GetDateTimeStep(Steema.TeeChart.DateTimeSteps.FifteenMinutes);
sb_giag
Post by sb_giag » Thu May 27, 2010 12:12 pm
Hi Sandra
This is definitly NOT a solution, only a workaround. You have to fix this bug.
Our customer is not forced to set the min and max property.
If he does not set these properties and loads a chart with this two values, our application hangs.
Thanks Stefan
sb_giag
Post by sb_giag » Fri May 28, 2010 7:23 am
Hello Steema
.. no reply ?
Can i assume that this bug is fixed in the next version ?
thanks stefan
Post by Sandra » Fri May 28, 2010 8:51 am
Hello Stefan,
Ok, I have added your problem in bug report list with number [TF02014915]. We will try to fix it for next maintenance releases of TeeChart.Net. Also, I have made other workaround that check when you add a new point.
            Steema.TeeChart.Styles.Line line1 = new Steema.TeeChart.Styles.Line(panel1.Chart);
            line1.Add(1);
            line1.Add(1, 0.99999999999999989);
            CheckLeftAxis();
        private void CheckLeftAxis()
            double diff = panel1[0].YValues.Maximum - panel1[0].YValues.Minimum;
            if (diff < 0.0000001)
                panel1.Axes.Left.SetMinMax(panel1[0].YValues[0] - diff * 1000, panel1[0].YValues[1] + diff * 1000);
sb_giag
Post by sb_giag » Tue Jul 06, 2010 1:37 pm
Am i right that you din't fixed this bug in the june release ?
What's your roadmap ?
Post by Sandra » Thu Jul 08, 2010 9:04 am
Hello sb_giag,
We haven't forgotten this. We are investigating it and we'll be back here asap.
Post by Sandra » Fri Jul 09, 2010 8:50 am
Hello sb_giag,
After several tests, we decide close the bug as not bug. Because, by default a Double value contains 15 decimal digits of precision as explained in this link: http://msdn.microsoft.com/en-us/library/643eft0t.aspx. You can check it, with next code that works fine here with next version of TeeChart .Net
        private Steema.TeeChart.Styles.Line line1;
            line1 = new Steema.TeeChart.Styles.Line(tChart1.Chart);
            line1.Add(1, 1.0);
            line1.Add(2, 0.999999999999999);//15 decimal digits - ok
            //line1.Add(2, 0.99999999999999989); //17 decimal digits - not ok
            line1.ValueFormat = "N15";
            tChart1.Axes.Left.Increment = 1e-15;
            tChart1.Axes.Left.Labels.ValueFormat = "N15";
On the other hand, if you want that 0.99999999999999 value appears in Left axis labels, you need change tChart1.Axes.Left.Increment and tChart1.Axes.Left.Labels.ValueFormat, as do in the code of this post, because difference between 1 and 0.99999999999999 is very small.
Post by Marc » Wed Jul 21, 2010 2:19 pm
Latest status for this thread: A code fix has been made for this issue, to be included with the next maintenance release.
