Can Teechart use Cylinder Candle series?
customize every cylinder color (use Gradient)
How to implement this function?
JoJo
Candle series question
- K_Bar.png (2.23 KiB) Viewed 1969 times
Re: Candle series question
Hi JoJo,
I'm afraid that this style isn't available for TCandleSeries. Right now, you could use TBar3DSeries and draw the two vertical lines with custom drawing techniques. For example:
uses TeCanvas;
const nValues=5;
var CandleDates, CandleClose, CandleHigh, CandleLow, CandleOpen: array of double;
var i: Integer;
tmp: double;
StartX: TDateTime;
SetLength(CandleDates, nValues);
SetLength(CandleClose, nValues);
SetLength(CandleHigh, nValues);
SetLength(CandleLow, nValues);
SetLength(CandleOpen, nValues);
Series1.XValues.DateTime:=true;
Series1.BarStyle:=bsCilinder;
Series1.Marks.Visible:=false;
Series1.Pen.Visible:=false;
StartX:=Now;
for i:=0 to nValues-1 do
CandleDates[i]:=StartX-nValues+i+1;
CandleClose[i]:=random*25;
CandleHigh[i]:=random*25+25;
CandleLow[i]:=random*25+50;
CandleOpen[i]:=random*25+75;
With Series1.XValues do
Value:=TChartValues(CandleDates);
Count:=nValues;
Modified:=True;
With Series1.YValues do
Value:=TChartValues(CandleLow);
Count:=nValues;
Modified:=True;
With Series1.OffsetValues do
Value:=TChartValues(CandleHigh);
Count:=nValues;
Modified:=True;
Chart1.Axes.Left.SetMinMax(0,100);
Chart1.Chart3DPercent:=100;
Chart1.Aspect.Orthogonal:=false;
Chart1.Legend.Visible:=false;
procedure TForm1.Chart1BeforeDrawSeries(Sender: TObject);
var i: Integer;
for i:=0 to Chart1[0].Count-1 do
DrawLine(Chart1[0].XValue[i], CandleHigh[i], CandleClose[i]);
var i: Integer;
DrawLine(Chart1[0].XValue[i], CandleLow[i], CandleOpen[i]);
procedure TForm1.DrawLine(XVal, YStartVal, YEndVal: double);
var XPos, Y0Pos, Y1Pos: Integer;
tmpPoints: TPointArray;
SetLength(tmpPoints,2);
XPos:=Chart1.Axes.Bottom.CalcXPosValue(XVal);
Y0Pos:=Chart1.Axes.Left.CalcYPosValue(YStartVal);
Y1Pos:=Chart1.Axes.Left.CalcYPosValue(YEndVal);
Chart1.Canvas.Pen.Color:=Chart1[0].Color;
tmpPoints[0]:=Point(XPos,Y0Pos);
tmpPoints[1]:=Point(XPos,Y1Pos);
tmpPoints:=Chart1.Canvas.Calc3DPoints(tmpPoints,(Chart1[0].EndZ - Chart1[0].StartZ) div 2);
Chart1.Canvas.Line(tmpPoints[0],tmpPoints[1]);
