How to set Axis draw width?
moelski
Post by moelski » Wed May 12, 2010 7:51 am
Hi !
Actually I plot 3D points into a chart to visualize GPS data. It works fine but I have one problem ...
The Axis draw width is set automatically. The result is that the 3D plot is streched. What I need is to set the draw with of axis.
Let me explain it with an 2D example :)
You log GPS data and drive down straight a road. Take a look at picture 1. You could get a problem that one or more axis don´t fit to the GPS data because it´s streched.
What I need is to reduce (for example) the size of the X axis. Take a look at picture 2.
The redurced axis width would fit exactly to my GPS data.
As I said before ... It´s only an example what I need to achieve. The exact dimensions for the axis could be calculated through the GPS data.
And sorry for the bad painting :D
Picture 2 - reduced X Axis draw width
Picture 1 - streched X Axis
Re: How to set Axis draw width?
Post by Yeray » Wed May 12, 2010 2:23 pm
Hi Dominik,
I'm not sure but I think you would like to have something similar to Isometric Axes, isn't it?
Take a look at the demo at All features\Welcome !\Axes\Isometric Axes.
