GetPointerStyle - bug
petroV
Post by petroV » Wed May 05, 2010 5:41 am
Have bug with GetPointerStyle. I want draw only first points in some series. I have two charts with some series, series on different charts have same DataSource.
Result - first chart draw two first points, second chart don't draw first point in first series.
What do i wrong?
my code:
    private void lineSeries_GetPointerStyle(Steema.TeeChart.Styles.CustomPoint series,
      Steema.TeeChart.Styles.GetPointerStyleEventArgs e)
      e.Style = Steema.TeeChart.Styles.PointerStyles.Nothing;
      if (series.DataSource == null)
        return;
      DataTable chartTable = series.DataSource as DataTable;
      if (chartTable.Rows.Count > 0 &&
        e.ValueIndex == 0)
          e.Style = Steema.TeeChart.Styles.PointerStyles.Circle;
          e.Color = clPointColor;
Re: GetPointerStyle - bug
Post by Sandra » Wed May 05, 2010 10:25 am
Hello petroV,
I couldn't reproduce your problem with last version of TeeChart .Net. Please, you could send us a simple project, because we can reproduce it here? You could make a DataSource to runtime as explain in this thread.
petroV
Post by petroV » Wed May 05, 2010 11:20 am
i found proplem - it happen, when Left axe inverted
in attach sample project
TestTeeChart.rar
(49.95 KiB) Downloaded 369 times
Post by Sandra » Thu May 06, 2010 11:04 am
Hello petroV,
I could reproduce your problem, and I think that you didn’t draw first points to series, because your code only works with points of first series:
void line_GetPointerStyle(Steema.TeeChart.Styles.CustomPoint series, Steema.TeeChart.Styles.GetPointerStyleEventArgs e)
      int i = tChart2.Series.IndexOf(series);
      if (i == 0 && e.ValueIndex == index)
I modify your code and work correctly with last version of TeeChart .Net. Please, check next code works as you want
    private void Form1_Shown(object sender, EventArgs e)
      Random rnd = new Random();
      double x = 0;
      double y = 0;
      double z = 0;
      tChart2.Axes.Left.Inverted = false;
      tChart2.Aspect.View3D = false;
      for (int i = 0; i < 4; i++)
          Steema.TeeChart.Styles.Points3D points = new Steema.TeeChart.Styles.Points3D(tChart1.Chart) { Visible = true };
          Steema.TeeChart.Styles.HorizLine line = new Steema.TeeChart.Styles.HorizLine(tChart2.Chart);
          line.GetPointerStyle += new Steema.TeeChart.Styles.CustomPoint.GetPointerStyleEventHandler(line_GetPointerStyle);
          line.Pointer.Visible = true;
          line.Visible = true;
          for (int k = 0; k < 50; k++)
              points.Add(x, y, z);
              line.Add(x, y);
              x++; y++; z++;
          x--; y--; z--;
      if ((e.ValueIndex == 0) || (e.ValueIndex == 1))
Ok, I can reproduce it and I have added in bug Report list with number [TF02014856]. We will try to fix for next versions of TeeChart .Net.
On the other hand, I recommend change property Inverted= true, to Inverted=false, for now.
petroV
Post by petroV » Thu May 06, 2010 11:48 am
Thanks, will wait next version
