Synchronize zero axes
franckgar
Post by franckgar » Fri Apr 09, 2010 10:29 am
is there an option to simply synchronize the zero of left and rigth axes like this :
and not like this
thanks in advance
Re: Synchronize zero axes
Post by Yeray » Fri Apr 09, 2010 1:28 pm
Hi franckgar,
You should probably control your Left and Right axes manually with SetMinMax method at OnScroll, OnZoom, OnUndoZoom,.. events.
If you have problems with it, please, send us a simple example project we can run as-is to reproduce the problem here.
franckgar
Post by franckgar » Fri Apr 09, 2010 1:52 pm
Thanks for your response
yes of course if I control manualy left and rigth axes I can synchronize theirs zeros ... but I will lose the "automatic scale" of these axes.
Any other solutions ?
regards
Post by Yeray » Fri Apr 09, 2010 2:31 pm
Hi franckgar,
If you can arrange a simple example, maybe we will be able to understand better your specific situation and try think in a way to achieve the desired behaviour.
