Axis labels wont take font changes
OptUser
Post by OptUser » Tue Mar 09, 2010 8:33 pm
I have a problem with the font of the bottom axis labels. When I clear the label collection and add them myself, the font for those labels reset to a default font and size and cannot be changed.
Attached to the post there is a project I've built to show the problem.
The issue is found in TeeChart ActiveX Version 8.0.0.6 and 7.0.1.3
I really need to fix that problem, please advise what can I do about it.
ChartAxisLabelBug.zip
VB project showing the problem.
(2.47 KiB) Downloaded 535 times
Re: Axis labels wont take font changes
Post by Yeray » Wed Mar 10, 2010 3:53 pm
Hi OptUser,
I've reproduced it so I've added it to the defect list to be fixed in future releases (TV52014727). It seems that font changes aren't applied to the axis labels when using custom labels.
OptUser
Post by OptUser » Mon Mar 15, 2010 9:52 pm
Hi, thanks your response.
Can you suggest a workaround I can use meanwhile it is being fixed?
I need to define specific values for the bottom axis and the only way I could make it work is clearing the label list.
Post by Yeray » Tue Mar 16, 2010 10:57 am
Hi OptUser,
Of course, you always can draw text directly to the canvas. Here is an example:
Private Sub Form_Load()
  TChart1.Aspect.View3D = False
  TChart1.AddSeries scLine
  TChart1.Series(0).FillSampleValues 25
  TChart1.Axis.Bottom.Labels.Clear
  Dim i As Integer
  For i = 0 To TChart1.Series(0).Count - 1
    TChart1.Axis.Bottom.Labels.Add TChart1.Series(0).XValues.Value(i), " "
  Next i
  Dim i As Integer
  With TChart1.Canvas
    .Font.Name = "Tahoma"
    .Font.Size = 7
    .Font.Bold = True
    .Font.Color = vbBlue
      .RotateLabel TChart1.Series(0).CalcXPos(i) - (.TextHeight("hello") / 2), TChart1.Axis.Bottom.Position + .TextWidth("hello") + TChart1.Axis.Bottom.TickLength, "hello", 90
    Next i
  End With
Note that first of all, I've cleared the labels and added custom labels with the text " " to show the grids but not any text.
