missing X labels on multiple line series
Jonathan
Post by Jonathan » Tue Mar 09, 2010 5:35 pm
When I created two line series, x labels from the 1st series are missing. ex)
	public static void main(String[] args) {
		JFrame frame = new JFrame();
		JPanel panel = new JPanel();
		panel.setSize(600, 600);
		TChart chart = new TChart();
		panel.add(chart);
		Line line1 = new Line(chart.getChart());
		line1.add(1, 4, "D"); //index, value, label
		line1.add(3, 2, "C");
		Line line2 = new Line(chart.getChart());
		line2.add(0, 1, "A");
		line2.add(2, 2, "B");
		frame.add(panel);
		frame.setSize(600, 600);
		frame.setVisible(true);
In this code, I should have A, D, B, C as X labels. However, I have only A and B. How would I displayed all labels with remaining the lines?
(Interesting note: while the 1st code displayed all index values, the 2nd code doesn't displayed all text labels)
chart.getAxes().getBottom().getLabels().setStyle(AxisLabelStyle.VALUE);
chart.getAxes().getBottom().getLabels().setStyle(AxisLabelStyle.TEXT);
Re: missing X labels on multiple line series
Post by Yeray » Wed Mar 10, 2010 3:26 pm
Hi Jonathan,
Take a look at this thread where this has been already discussed. Resuming, you can use custom labels or a dummy series with all the values set as null, but with all the labels you would like to appear.
Jonathan
Post by Jonathan » Thu Mar 11, 2010 5:43 pm
I read the thread, but no luck. I pasted the codes I tried. Pls. help me how to display "A", "D", "B", "C" on x axis on my chart.
		panel.add(chart);
		//chart.getAxes().getBottom().getLabels().setStyle(AxisLabelStyle.VALUE);
		chart.getAxes().getBottom().getLabels().getItems().clear();
		chart.getAxes().getBottom().getLabels().getItems().add("A");
		chart.getAxes().getBottom().getLabels().getItems().add("D");
		chart.getAxes().getBottom().getLabels().getItems().add("B");
		chart.getAxes().getBottom().getLabels().getItems().add("C");
		frame.add(panel);
Post by Yeray » Fri Mar 12, 2010 4:35 pm
Hi Jonathan,
Try with the ...getItems().add(double, string) method. To create the custom labels you have to control what is written on them but also where. The following seems to work fine here:
        Line line1 = new Line(tChart1.getChart());
        Line line2 = new Line(tChart1.getChart());
        tChart1.getAxes().getBottom().getLabels().getItems().clear();
        for (int i=0;i<tChart1.getSeriesCount();i++)
            for (int j=0;j<tChart1.getSeries(i).getCount();j++)
                tChart1.getAxes().getBottom().getLabels().getItems().add(tChart1.getSeries(i).getXValues().getValue(j), tChart1.getSeries(i).getLabels().getString(j));
ZooX
Post by ZooX » Wed Mar 24, 2010 5:00 pm
This is not the best way to do this, for every series you have you will be over-drawing the label which looks like hell.
Post by Yeray » Fri Mar 26, 2010 3:05 pm
Hi ZooX,
You could add some condition in the for loop where the custom labels are added to control that manually.
ZooX
Post by ZooX » Mon Jun 14, 2010 6:13 pm
I could but don't you think as a paid for library you should handle this?
Post by Yeray » Thu Jun 17, 2010 11:16 am
Hi ZooX,
I've added it to the wish list to be implemented in future releases (TJ71014978).
