Having same width on all TSeriesMarks
JohanI
Post by JohanI » Thu Feb 25, 2010 1:20 pm
Hi all,
I have run into a "strange" problem, im using a chart with a couple of TSeriesMarks, I only show the marks in the chart, no values etc... but what I want is that all Marks should have the same width, but setting the witdh property on the series TSeriesMarks or setting it on each mark individually doesnt seem to work. The widths still vary between the different marks.Ive set the width property to the series MaxMarkWidth property which in this case is 106. Have i missed something fundamental?
Johan Ingemansson
Re: Having same width on all TSeriesMarks
Post by Yeray » Thu Feb 25, 2010 4:29 pm
Hi Johan,
You should change TSeriesMarks' TSeriesMarksPositions' widths. Here it is an example:
var Series1: TPointSeries;
    i: Integer;
  Chart1.View3D:=false;
  Series1:=Chart1.AddSeries(TPointSeries.Create(self)) as TPointSeries;
  Series1.Add(10);
  Series1.Add(10.1256546456);
  Series1.Add(5);
  Series1.Add(15);
  Series1.Marks.Visible:=true;
  Series1.ValueFormat:='#.##########';
  Series1.Pointer.Visible:=false;
  Chart1.Draw;
  for i:=0 to Series1.Count-1 do
    Series1.Marks.Positions[i].Custom:=true;
    Series1.Marks.Positions[i].Width:=Series1.MaxMarkWidth+10;
